Thread: Hey from VA
    Hey from VA
    Just checking in, having a 30' agp installed in a few days. I got it from a local joint with some markup in trade for local parts support. Got them to change the too small filter(19') and to fast pump (1.5 HP) for a quality 244T and 1HP 2-speed. I've been reading up so I can be somewhat smart here. Looking to add an SWCG (all resin pool) and looking in the 40K gallon service range (I'll have approx 24k in the pool).
    Anyhoo...figured I'd check in before my problems start.
    Tim
    22,548
    Re: Hey from VA
    Welcome.
    Looks like you've done your homework.
    Feb 2008
    Denton, TX
    5,061
    Re: Hey from VA
    Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hey from VA
    Welcome to the forum
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hey from VA
    Welcome to TFP!!
    Where about in Va are you? (I used to build and service pools in the Richmond area- I also went to college at W&L in Lexington)
    I want to congratulate you on coming here, reading and learning and knowing enough to get the better system than the one they'd have given you
    Keep reading and get a good test kit and... the problems WON'T start
    Luv& Luk
    -Ted
