Thread: New pool numbers
    New pool numbers
    Fc 3.6
    Cc <1
    Ph 7.2
    Ta 70
    Ch 310
    Cya 85
    Borate ~60
    Water temp 90
    Thoughts?
    Size 12,000 gal | Filtration Jandy 340 CL Cartridge | Sanitation Jandy 1400 AquaPure SWG | Placement In-ground Gunite | Finish Medium Gray Plaster | Automation Jandy Aqualink RS w/PDA6
    Pump Jandy 2.5hp 2 speed Stealth | Location New Orleans LA
    Heat Jandy EE2000t
    Test kit Taylor K-2006 (fas-dpd)
    Re: New pool numbers
    Your numbers look fairly good. With CYA at 85 and a SWG, you want FC at 4 or higher, so you might want to bump up the percentage setting on the SWG a little.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, the FC is a touch low and if the CC, reported as <1 is more than .5, that is too much CC.
    Don't let your FC drop below 4.
    You're done SLAMing when:
    Thank you very much for the feedback!
    I will bump the swg output from 30% to 40% and monitor it till I maintain 4ppm.
    Heat Jandy EE2000t
