Thread: *NEWBIE* Looking for help on liners and where to buy!!
    Hello, I was looking if someone could give me a hand in picking the type of liner and help me in where to buy my supplies at. My local retailers are priced reasonable for here, but I'm also looking online.
    I live in New Brunswick, Canada, so I would have to have my liner winter ready in the fall, I will check into the process a little later in the year.
    I bought my pool second hand and I am almost set on the J Hook (unibead) liner as it seems the easiest to set up, and I will have a deck around the pool. My pool is an aboveground SOLEX 24' round that is 52" high. I was initially thinking about converting to salt water chlorinators, but one thing at a time, maybe next year.
    My local retailers have TRIAC liners that they are pretty set in selling. I also see that there are SWIMLINE liners available online. Which are better liners, both say they are 20 mil liners and virgin vinyl?
    Finally, the online retailers I was looking at are (all dot coms) POOLSUPPLIESCANADA, International Pools and Spas, NORTHWEST WHOLESALE, BACKYARDPOOLSUPERSTORE. Has anyone had good reviews or a better place to buy?
    Thanks for the time, just a new person here to the pool game.
    24' Round Above Ground, Metal by SOLEX
    Heat Pump, Focus Temp INSTAMAHK 80
    Hayward S-180T Sand Filter
    Hayward Ultra Pro LX Pump
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: *NEWBIE* Looking for help on liners and where to buy!!
    If your still looking this http://www.shadebuilder.com/Above-Ground-Pool.html has a lot of info about setting up used agp's and sources.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I've heard good things about Northwest Wholesale, I came very close to buying my AGP from them, only reason I didn't was because I found a bit of an odd ball sized pool elsewhere and it fit my yard better. They also seem to have good prices on a lot of things.
