Results 1 to 7 of 7
Thread: Re: Goldline generator
    Does anybody know why my Aqua Rite RS8 salt system control panel in the house reads solar sensor short and my pool temp is showing a false reading of 131 degrees?
    Topics merged. Please only ask questions in one place.
    AQUA RITE RS8 SALT SYSTEM
    Does anybody know why my Aqua Rite salt generator RS8 systems control panel is reading solar sensor shorted out and the pool temp is showing a false reading of 131 degrees?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: AQUA RITE RS8 SALT SYSTEM
    Welcome to TFP!!
    My first guess would be a bad sensor
    Luv& Luk
    -Ted
    Ted thanks for the information. Do you know what sensor it would be?? I have done some research on them and it seems there are two types. one a temp sensor and one a flow sensor. Could you give me the type and possible description and location of where it might be located at the pool equip.
    Those error messages/problems both involve temperature sensors.
    Re: Re: Goldline generator
    Thanks for the info. I have replaced temp sensor and still have those messages???? What next!!!
    Do you have a multi-meter? The next step is to measure the resistance of the sensor when it is disconnected from the control box, and then triple check that it is connected in the correct place.
