Thread: Liquidator - New pump motor and now way too much flow!
    JoseJones
    Guest
    I have a little but annoying dilemma now with my 2 year old Liquidator.
    I recently replaced my pump motor (same model as org) and now I can't keep the Chlorine levels low enough. I guess my old motor really wasn't running at capacity nearly at all.
    The wierd thing is I can dial the flow to keep the ball down by 1 or 2 and it'd stay there. But the volume of clorine coming out is massive. I soaked the check valves and flow valve (all original with unit) in acid as mentioned in other posts. This didn't help. So I upgraded to the to the Hayward Needle valve others mention for more control. This has helped a little, but the Chlorine level still creeps up over time. I'll look one day and it'll be 7ppm or higher and then I'll shut the valve completely off for a day, then try again, then the cycle continues.
    I don't know what the PSI is, I know I need to check this. What range should I be in PSI wise? And what tool do I need to get to measure this? Assuming it will be astronomical, what can I do?
    Thanks in advance.
    Jose
    22,553
    Re: Liquidator - New pump motor and now way too much flow!
    Sounds like there's a problem with the flow meter. Just keep turning down the flow till your testing levels out. Don't worry about what the flow meter says.
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    If your using %12 chlorine, try %6.
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    JoseJones
    Guest
    Sorry, didn't mean that I actually think the flow meter means anything. Just that before this was super low flow and a good yard stick. I've actually been running it so low the ball doesn't even pop up, or completely shut off. But even a little bit of flow increases the CL substantially. I guess this is the new reality?
    Have no idea where I would get 6% CL. Like getting the cases from the local pool store once a month. Get to flirt with the cute manager.
    Jun 2011
    Niagara Falls. NY
    34
    Bleach is 6% pick it up at Walmart or Aldi
    Niagara Falls, NY
    27' Vogue Revelation Round 54" AG Pool = ~19000 gallons with solar cover
    GLI 28ft Whirlwind Above Ground Solar Reel System with 4" Tube
    BBB using TF-100 test kit
    Hayward EC50C93STL System
    1.5HP Power-Flo Matrix Pump runs from 8AM till Midnight ( Overkill ?)
    EC50AC Perflex D.E. Filter
    JoseJones
    Guest
    I have a crazy thought.
    Besides installing the new pump, I picked up a new Prowler 720 robot and new pool filter cartridge. The Prowler's filter bag is 2 microns, and pool filter has only moved up from 12 PSI to 14 PSI since I installed it, and started using the Prowler on a almost daily basis. The pool gets a lot of debris and I only would vacum it out once a week before, so its much cleaner now than ever. Could this lack of organics sway the number this much? I guess I should be doing the OCLT to see how much organics are eating up my CL?
    Thanks.
    Jose
