Thread: Question Concerning the Amt of MA Required at Different pH
    Jun 2008
    Texas
    132
    My water chemistry:
    FC = 5
    TA = 80
    CH = 230
    Borates = 20
    CYA = 65
    When I use the Pool Calculator I get the result that to change the pH from 8.0 to 7.6 I need to add 57 oz of MA.
    To change the pH from 7.4 to 7.0 I need to add 78 oz of MA.
    In the first case a decrease of the pH of .4 requires 57 oz of MA and in the second case a decrease of the pH of .4 requires 78 oz of MA.
    I would have expected that the amount of MA required would have been the same; perhaps it has been too many years since I took chemistry. Can you explain why more MA is required to lower the pH when the starting pH is lower?
    If you watch the pH levels for eye comfort and the CSI index this result implies that you can reduce the amount of MA used by maintaining your pool at a higher pH level.
    30,000 gallon gunite in-ground with a spillover spa, Diving board and water slide
    Hayward 1 HP Super II filter pump, Hayward 24 " Sand Filter Pro Series using zeolite media
    Polaris 380 cleaner with ¾ HP booster pump, Hayward Heatmaster pool heater, AutoPilot DIG-220 Power Supply SC-60 cell
    Testing with the TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Question Concerning the Amt of MA Required at Different
    pH is logarithmic. Like the Richter Scale is for earthquakes. pH=7 is ten times more acidic than pH = 8.
    I don't know of any easy way to say it other than: PH is not at all linear. What is surprising is that it comes out anywhere even close to linear.
    To be rather more technical, PH is actually the negative logarithm (base 10) of the molar concentration of dissolved hydronium ions (H3O+). Several of the factors that affect PH, like buffering by TA and Borates also have non-linear components.
    We recommend keeping PH between 7.5 and 7.8, not because of what you just described, but because of the rate of CO2 outgassing is lower at higher PH.
