Thread: Good thing I was home.
    Jul 2010
    Mickleton, NJ
    229
    All has been well with the pool here. I had the filter running today and had the kids in the pool a few hours earlier. About an hour ago I went to wash my hands and as I looked up I noticed through the kitchen window that the pool water level was just to the bottom screw on the skimmer. It was above the second screw earlier in the day. I ran outside to see the hose that connects to the pool was laying on the ground gushing water as well the return hole. I shut off the pump and reconnected the hose to the return. I just finished refilling and turned the pump back on, there seems to be some air in the system so I bleeded out on the filter. I did notice the hose from the filter to the return seemed to be shaking, not sure if I've seen this before and am just noticing it now or what. I turned it off just incase, I'm wondering if air is still trapped in there.
    Any idea what caused this to happen and what is the best way to prevent it in the future? If I was not home at the time I think it could have been really bad, pump running dry, liner tearing etc. It is really really hot here today, water temp is now 90 degrees (this is after refilling like 6 inches with the hose). I feel like the hose was secure, we spent some time adjusting it back in April when we opened the pool and haven't had so much as a drip since then.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    Re: Good thing I was home.
    The connection at the eyeball return failed?
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    22,550
    I know you don't want to hear this but that's why hard piping the pump and filter is so much better than the hoses. Having said that, you can double clamp the connections and it may help some.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    Melissa, the same thing happened to me a while back. Do you have clamps that tighten around the hoses to hold them securely? Apparently the vibration of the pump running had caused the screws to loosen on mine.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Jul 2010
    Mickleton, NJ
    229
    That was actually the first thing I thought of when this happened. "so this is why people hard plumb their above grounds."
    After dh and I tried numerous times to get the clamp tight and the hose leaking or not staying on I went to the pool store (first time there this season)lol. I bought a new hose, it was a little thicker than that one that came with the pool installation. The owner who sold me the pool said it's a good idea to replace them every year or hard plumb the lines. I think with yesterday's heat here it just made the plastic moer plyable or something. The new one fit more snug at both ends and is on securely with the clamp.
    Dh and I are going to hard plumb next spring.
    Currently Pooless
    I'm hard plumbing in the next few weeks. I just recently upgraded my pump and cut the liner for the larger connections and I still had a plunger fall off. Thankfully it did it while I was doing maintenance and was able to correct it before losing too many gallons. I hate those plungers and can't wait until I get ball joints in their place.
    Intex 15' X 48' pool, 2500 GPH pump, SWG. Using old 1000 GPH as my aerator/heat pump.
