Thread: Brass? Check Valve
    Brass? Check Valve
    I am not sure about this thing.It is in between the impeller and the mulitport. I want to replace it. I think its corroding and causing metals in the pool...hence my recent issues with brown stains. Any ideas? Just replace with a piece of SCH40
    Newbie in Hampton, Virginia
    TF-100 test kit
    18' round x52" /Sharkline Heritage /8000 gal /vinyl AGP
    Intex 2650 GPH, 1 HP, sand filter and SWG combo
    Solar cover
    Re: Brass? Check Valve
    Its like this but larger of course
    TF-100 test kit
    Solar cover
    That looks like a check valve. There aren't all that many other things it could be.
    You might need a check valve in that location, depending on how your plumbing is setup, though that really isn't a very common location for a check valve. Could you describe the rest of your system? Do you have a spa, solar heat, fountain, etc?
    No accessories. skimmer/main drain valve then pump basket just standard pump and impeller vertical PVC to lateral with brass check valve then filter
    TF-100 test kit
    Solar cover
    22,553
    I'd remove it and see how the system performs. If you have an issue, you could always add a PVC check valve in it's place.
