Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: 15' x 4' above-ground going up. Fun fun.
    Decided we were going to get a pool this year, something small/cheap, see how we liked it/how much we used it/fit our lifestyle etc. If things go well, then get rid of this and upgrade to a 'real' pool in a couple years. Don't want to put too much up front if things don't work out.
    Bought this here:
    http://store.namcopoolstore.com/web13931.html
    Pool/filter/pump/locking sliding ladder/in-wall skimmer was $799. Figured I would spend a couple hundred more than the Intex pools that are sold-out all over anyways. I can get the specs on the other stuff later when I get home.
    Found what I figured to be the best part of my yard, and leveled it down for the pool. Somewhere in the sun, that wasn't a hike to the house.
    EDIT: Better 'progression' pics.
    Beginning, grass cleared. As you see the other pics, you'll have an idea of what kind of 'grass' I had to clear out.
    I'm in serious need of a makeover. Probably reserve that for another thread.
    Corners dug down to the level of the lowest corner.
    Half cleared.
    Mostly cleared.
    Just a little too small.
    Current status.
    I'm unsure what to do about that high ground on that backside of it. A lot of it is sandy dirt that was dumped from my dog pen project, so it needs to be spread, but the 'true' ground level there is still a good 10" or so. Going to rip all that junk out you see growing everywhere as well, get it nice looking. Then I need to figure out how to landscape it nicely. And, undecided if I want to build a small deck for it or not; depends on how much I can get the materials for.
    I've heard to put plastic down under the tarp to keep the sand from washing away, what's the deal with that? Between the sand and ground?
    17K saltwater, freeform pebbletec with spa; Hayward cartridge filter, Hayward Northstar 2.4HP 2-speed pump, Hayward H400 heater. Hayward T-CELL-15 salt cell.
    Re: 15' x 4' above-ground going up. Fun fun.
    Got the holes for the post footings dug yesterday, pavers set and leveled, bottom ring, and pool side up. Inside filled with mason sand. Today will be tamping the sand, building/packing the cove around the edge, and putting in the liner.
    Ugh, buddy rushing me, for got the brackets that go on either side of the seam.
    30,415
    Looks nice, Dave. If that's the biggest mistake, you'' be fine. The SINGLE biggest error we see here onthe forum is folks not getting the pool almost perfectly level....1/2 inch out of level is about the maximum.
    Well, I tried my ****dest! My soil is very sandy where I'm at. When I was digging out, 2/3 of it was over sandy base, and the other 1/3 was over compacted soil, heck if I know how that worked out. First I tried using strings to level it. Every time my dogs went out they'd run through it and knock down the stakes, PITA. Then I put a stake in the middle, lowest point with a metal L-bracket and a level and worked it in a circle. Seems to be level. Biggest pain was leveling all the footings for the posts. We'll see what happens. I don't have my help today, hopefully I can do my liner myself.
    I'm hoping the AGP forum has some ideas to pretty it up once it's done. My yard needs a LOT of work.
    Update with progress pics. Today was spent swimming in a buddy's pool instead of working on mine.
    Yesterday was a bad day. Cliff notes (putting-up-an-agp-sucks-i-m-about-to-drive-over-it-t36912.html) : Somehow during the building of the sand cove, I knocked the pool wall out of the u-channel. Didn't notice it until I had the liner in, getting ready to fill it, and was hooking the shop vac up to the hole in the wall. Had to dig out the sand cove, put the wall back in place for half the pool (yeah, it fell over on me too when I was trying to fix it, so it all fell out), tamp sand back down in place inside, and install the foam cove. Put the liner back up, and now I'm filling it.
    Not been fun.
    My painstakingly built-by-hand sand cove.
    Which, during the build process, caused the wall to pop out of this groove:
    All the cove dug back out.
    Foam cove, $6 per 4ft locally, adhesive backed. Should have gone with this the first time, had this set up in no time.
    Liner back in, filling with water.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Methinks that twin party did you some good. Glad to see you went with water instead of using your vehicle on it :~} Those little peeps who like to swim will be so happy tomorrow!
    Don't forget the chlorine btw... Let us know if you have water questions.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    Quote Originally Posted by frogabog
    hahaha I was thinking the exact same thing... It would've been so sad for all of his hard work to go to waste. I can't wait to see the finished product. It'll look great I bet.
    5,061 Gallon 16' x 48" Intex Metal Frame Pool
    14" Intex 55Ib Sand Filter and Pump.
    _______________________________________
    Location: Columbus, GA Where the Heat and the humidity are* :)
    Jul 2010
    Mickleton, NJ
    229
    Looking good, your hard work and presistence is paying off. We can def. give you some landscape ideas when your are ready. After we had our ABG installed last year our yard was a mud put of dirt and dead grass.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Columbus Ohio
    178
    lets see it with that water in it!! Great job!!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Thanks. It's coming along. Started working on it after work yesterday, about 8 pm. Got the liner about where it needs to be so I can start putting the top rail on. There are 2 top rails, one structural, one decorative. The structural one was not cut very cleanly, so there are a lot of burrs etc. Started filing all those off so they will slide smoothly into each other. Had 2 left to file, and it started thunder storming and lightning.
    Figured it was a bad idea to hold long metal rods outside in a storm, so had to call it quits for the night. Let's see what today brings.
    And yes I'm definitely going to need landscape ideas. I have no issues being the back and brunt of labor, but I lack creativity.
    Western Pennsylvania
    151
    Lots of hard work!, I have never seen one without upright supposts.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    Oh it has posts. I just got them on tonight!
    Got done putting on the rails and vertical supports. "Shaken vigorously" into a perfect circle as in the instructions. I was afraid to do it too vigorously, afraid the wall would pop out of the bottom U-Channel again! Ah well it should be good.
    Filling with water now. Tomorrow, pump & filter!
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    Quote Originally Posted by Dave88LX
    wow! It looks great!
    Jul 2010
    Mickleton, NJ
    229
    Looking good.
    Currently Pooless
    Oh. It's not the pool that is crooked. It's my yard. Now to figure out WTH to do around it.
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    have you thought about building a small deck around it?
  20. Back To Top    #20
    Got the skimmer and return in, pump hooked up. Waiting for the last couple/few inches to fill.
