Results 1 to 13 of 13
Thread: Help!
    Jul 2011
    Gordon, GA
    18
    Help!
    First....hi everyone! New pool owner and board member here. I have a quick question.....
    I started up my intex SWG last night and this morning the hose that goes from the SWG to the pool is brown. What in the world is wrong?? I am in the process of trying to get the water right and have it tested today.
    Thanks!!
    AG Intex 5300 gal (15x48)
    Intex SWG 700 gal/hr
    22,553
    Re: Help!
    Do you have metals in your fill water?
    Jul 2011
    Gordon, GA
    18
    Re: Help!
    Probably....it is city water and we have bad plumbing. Wouldn't the water and the hose going into the filter be brown also though?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help!
    When I was running a intex pool (12X30) last year and added the intex swcg, my outlet hose also went brown. I fill with a well that has metals.
    Jul 2011
    Gordon, GA
    18
    Re: Help!
    What do I need to do? Wait until I test the water?
    22,553
    Re: Help!
    You can add sequestrant to see if it goes away.
    What does the water look like?
    Jul 2011
    Gordon, GA
    18
    Re: Help!
    The water is a little cloudy with a green tint to it.
    22,553
    Re: Help!
    Could be that you just need to shock. Can you post a set of test results?
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Re: Help!
    Is the copper ion generator connected?
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Jul 2011
    Gordon, GA
    18
    Re: Help!
    Sorry for the delay in answering. I had to purchase a test strip kit to get me by until I can order a good kit.....Leslies' was out
    Anyway....everything is pretty much registering 0. My salt test showed between 2000 and 3000.
    I have the newest model Intex SWG and I haven't unplugged the copper ion generator assuming it has one. Do I need to? Which plug is it? The big or little one on the top?
    Thanks for all your help!!
    Jun 2010
    Glendale, CA
    513
    Re: Help!
    Quote Originally Posted by Valentine
    Leslies' was out
    tftestkits.com will have better kits for better prices. The TF-100 is the kit most of us here use, or the Taylor K2006. Both of these kits use the same reagents - the TF100 is a little better value.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Jul 2011
    Gordon, GA
    18
    Re: Help!
    Quote Originally Posted by lightingguy
    Leslies' was out
    I guess I should have been more clear....I went by a Leslies pool store locally. Guess it was a good thing they were out!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help!
    On the new units, there are three cords. Disconnect the last cord in the direction of flow (it is the closest connection to the outlet back to the pool). You unscrew the retaining ring then unplug the connector.
