Thread: Is My Liner Installed Right
    Jun 2011
    Northern Middle Tennessee
    32
    Hello Quick question concerning the installation of an inground vinyl liner. Should the seams where the wall and floor join on the liner match up with where the wall and the floor of the pool meet up
    Our liner matches good on the floor/wall of one side of the pool but the other is WAY off.
    Just curious if anyone else has had this issue.
    20 x 40 Double Roman Cardinal Inground Vinyl Liner With steel Walls, Saltwater, Hayward Light, 1.5 HP pump,Sand Filter, Jandy booster pump
    Jun 2011
    Central Pennsylvania
    17
    Re: Is My Liner Installed Right
    Do you have any pics? Its always good to see what you mean.
    thanks
    Tom
    1) 16X32 IG Vinyl 18,200
    2) Hayward 120 Sq.ft. cartridge
    2) Hayward Super Pump 1.5HP
    3) AquaRite Salt Water, Turbo Cell
    22,541
    Sounds like either the measurements were a little off or the installers missed lining it up perfectly. If it's smooth and no wrinkles I wouldn't worry about it.
    Jun 2011
    32
    Thanks for the replies I tried to add pix but my file size is too large. when I figure out how to make it smaller I will post them
    Feb 2011
    Sicklerville, NJ
    80
    I just built my pool and I know my measurements are perfect, yet one wall seam in the shallow end lies slightly above the floor and then on the other side the seam is slightly on the floor. The seams were perfectly in the joints while the vacuum was on while the pool was filling. It was only when the pool was done and we were in it that I noticed the difference. I don't know what happened but I thought that, since it is a "lazy-L" that when the deep end filled, it put slightly more tension of one side so that when the shallow end filled it kind of migrated that way. There are no wrinkles or other issues so I'm not too worried about it.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    Jun 2011
    32
    Thanks MajorDIYer. We do have one or two wrinkle at the wall/floor in the deep end radius' that bother us . On the side where the floor/wall seam is off the waterline on the tile decoration is off too making it very noticeable. It has to be the liner because the water level around the pool is within 1/4 of an inch . Sooooooo frustrating
