Thread: Zero amps and zero instant salinity reading
    Feb 2010
    Sacramento, CA
    35
    For the past two days I have noticed something with my SWG. It seems to be working fine in the late morning. It is generating, I see the bubbles coming from the return and the panel says it is generating. However, when I come home in the afternoon, it still says it is generating on the panel but there are no bubbles coming from the return. And then when I go into the diagnostics both the amps and instant salinity say zero. What does this mean? Thanks for any info.
    Rgds,
    Dominick (Inground Pool Newbie)
    650 sq/ft - 20k gallons
    Free-Form Gunite with Granite Ansylbrite Finish
    40 sq/ft 18' raised spa
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    Jul 2011
    phoenix
    133
    Re: Zero amps and zero instant salinity reading
    have no idea but I know the people that might know will probably need to know what swg you have
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Feb 2010
    Sacramento, CA
    35
    Good idea. It is a Goldline SWG and it has a t-15 cell. The pool was put in last summer so the unit is just under a year old.
    Rgds,
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    22,548
    What percentage do you have it set on? It may be in the off cycle. I.E. if you have it set for 50%, that means it's on half the time and off half the time. I think that's per hour.
    Oct 2010
    Georgia
    317
    Normal operation for the Aquarite system
    The generating light will stay on even when the system is in "time out" mode based on the output percentage.
    The output percentage is based on time not voltage or amps.
    For example
    If we run the pump for 10 hours per day with the output set to 80%, then the unit is actually generating chlorine at a fixed production rate for only 8 of those 10 hours. If we look at the diagnostics menu during the 2 hours that the unit is in "time out" then the amps will be 0 and the instant salinity will read 0. No need to worry about the instant salinity, simply verify the average salinity weekly. This is the number that is constantly displayed on the LCD. 3200 is the ideal salinity for these particular units.
    PGS
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Feb 2010
    Sacramento, CA
    35
    Thanks for the replies. I'm still learning about this system and sometimes can't find the answers in the manual. Thank goodness for this board!
    Rgds,
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
