Thread: Skimmer question
    Skimmer question
    Can anyone tell what the name o\f this thing is and what exactly it does (see pics). I assume it it to close off the the skimmer so you only pull from the main drain. When I run my inteliflo on low rpm (1500) the skimmer does not work well. If I pull this thing out then the skimmer works much better. I have a dedicated cleaner suction in the wall.
    So, here are my questions
    1. How does this thing work?
    2. can I remove it?
    3. What is the disadvantage to removing it?
    I want to be able to utilize my inteliflo to the fullest. So far I have to keep it about 1600 to make the SWG turn on
    38x14.5 free form, Pebble Sheen Aqua Blue, reef step, 21,000 gallons, 6",12", and 18" raised bond beams. Raised spa with cascading water feature. Thin Stone "Desert Gold" ledge stone Veneer with matching coping and tile. 400K Master Temp, Pentaire DE filter, 1 4x160 and 1 2hp wisperflo. Intellichlor IC40 SWG, Easy Touch 8 controller with wireless remote and is4 spa remote. Deep heat and plumbed for solar and future water fall.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Re: Skimmer question
    Vacuum plate maybe???
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Jul 2011
    Stockton, CA
    63
    Quote Originally Posted by Jday92591
    2. can I remove it?
    1. The pivoting flap allows yo to vary the relative volume of water going back to the pump, either more or less from the skimmer vs. the main drain
    2. You could, but see no. 3.
    3. There is also a float inside. If your water level drops below the skimmer (ie, a big leak), the float drops down, seals the skimmer, and prevents the pump from sucking air. If you remove the entire device, you lose this protection
    I just installed an Intelliflo VS pump, and have had to fiddle with the pump speed to get adequate performance from the skimmers. I run mine at 1200 RPM for basic filtration, but bump the speed up to 1800 for an hour a day, just to get better skimmer flow. If you move the flap all the way open, you will maximize flow through the skimmer. But, you may still need to bump up the RPM. If you don't have much surface debris, you don't have to be too concerned about the skimmer function.
    22,500 gal, in-ground, plaster, Intelliflo VS 3050 pump, Sta-Rite 400 sq. ft. cartridge filter, solar panels on roof
