Results 1 to 8 of 8
Thread: new b this can't b this hard
    ok im a well user i filled up pool which is a intex metal frame it has about 4000gal(not totaly full ) with cheep filter it came with... shocked it .. it turned brown spent 8 days with towel around filter & towel in front of return to catch iron cleaned & replaced mant times daily tested with strips it was a bit high on ph, little cholorine, added clorx bleach again brown, someone said put iron out in it dumb me i put it in but it cleared up a bit then check # again no chlorine reseached iron out... takes chlorine out duh ! so got a little smarter took to leslies pool supplies
    fc 0
    tac 0
    ph 8.5
    ta 140
    cya 0
    calcium
    hardness 0
    copper/iron 0
    help me!! now what do i do? i would rather use the bbb method i am not given up herlp me
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: new b this can't b this hard
    You need to read pool school and particularly this: http://www.troublefreepool.com/pool-...ary_pool_guide. Pay attention to "Further Recommendations" section where it mentions the need of a good test kit!
    yes i need to get better filter & test kit but fund low right now will get better ones next week sorry calcium hardness was 170 not 0 i live in oklahoma i
    22,548
    You need a sequestrant, you just picked the wrong one. We recommend the ones based on HEDP or Phosphonic acid. Here's the article in Pool School about metals. Maybe it will help.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    CYA at zero (id accurate) is why you can not maintain chlorine
    Butterfly's Avatar
    South Carolina
    10,045
    First lower your pH to about 7.2, add the sequesterant, and then follow the directions in the link posted by linen for Temporary/Seasonal Pools.
    Dichlor will add CYA and chlorine at the same time.
    Post back in this thread with any questions.
    Use PoolCalculator.com to figure your doses.
    Welcome to the forum
    You're done SLAMing when:
    Thanks guys I will start there I have read so many different things on here my head is so full of good info I am having a hard time keeping thing straight sorry please be patient with me... as the cya these are the results the pool store gave me I was suprised it said no iron to because i know better, i will start with these sugestion thanks so much will post back
    Butterfly's Avatar
    South Carolina
    10,045
    Okay, good. When you get a moment, add your pool and equipment specs to your sig.
    Go to User Control Panel (upper left under TFP logo), select Profile, then Edit Sig.
    We know this can seem a little overwhelming at the beginning, but you'll soon be an old pro
