Thread: Pool Construction Pics
    We decided in the fall of 2009 to move. We started looking at houses with pools, and for the money we wanted to spend, the houses needed work and in some cases, so did the pools. So, we decided to start looking at houses in areas where pools tend to add to the value, and find a house to add a pool to. Of course, the first house we looked at had a nice hill in the back, and we ruled it out. Then after a couple weeks, we started coming back to this house as the one we really liked, and consulted our pool company on their thoughts on putting a pool in. No problem they said, and pulled out a book of other pools in the area in hilly yards. So we bought the house and ordered the pool. Construction started in late May 2010, and last just shy of 4 weeks. We are still picking away at fixing the yard up over a year later, but we have really been enjoying the pool. It's a 15x29 Onground, about 15 inches out of the ground at the front edge. Naturally, after it was built, I wished we had gone bigger, but we were kind of locked in by trees.
    Sep 2009
    Greentown, IN
    914
    Re: Pool Construction Pics
    Looks like you were landlocked by trees and that incline certainly didn't do much for making for a larger pool either. It looks as though you managed the largest you could for your situation and are far enough away from the trees to hopefully not have too much debris from them... unless they are down wind from them.
    Good work!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    kinda late now but I hope there is some subsurface drainage behind that retaining wall or dirt may wash into the pool when it rains. Just a perforated tube leading to either side of the pool would divert a ton of water when it rains.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Guest
    It looks very nice -- hope you'll include more pictures!
    What make is it?
