Results 1 to 7 of 7
Thread: Max amount Muriatic Acid per day?
    I've been trying to get my TA down (currently around 150) following the directions on this site to lower pH then aerate. My problem is that I can't seem to get my pH below 7.5. I read somewhere that you shouldn't add more than 1 pint of MA per 10,000 gallons per day. My pool is about 15,000 gallons, so I've been adding 1.5 pints per day, but this seems necessary just to keep the pH at 7.5.
    This is a new plaster pool (completed in April) . Here are my complete test results:
    FC 4.5
    CC 0
    pH 7.5
    TA 150
    CH 250
    CYA 50
    /Dan
    MEEKS-NE AL
    23.8K Gallon AG Vinyl BEAD Liner
    30' ROUND, 54" DEEP
    1.5HP SAND FILTER
    30,419
    Re: Max amount Muriatic Acid per day?
    Nope. Put in as much as you need to make the change you need. That said, it is a good idea to "sneak up" on the pH goal by adding say 70% or so of the amount calculated and then testing and adding the remaining dose to get to your goal.
    I have added 1.5 gallons in one shot to my pool. Granted, it's a fairly large pool but there is no "maximum" amount.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Wow, even with my small pool I would have never gotten anywhere with limiting myself to that amount per day. My dose for a while was 1/2 gallon of MA for a 5400 gallon pool. (Back when my TA was 325 -350).
    I would guess the 1 1/2 pints per day was something designed for people that do not undertand chemical interaction and are not on top of their water testing results. This might buy the manuf. some legal outs in case someone added too much and did damage to their pool.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    My fill water is 250-260 with a pH of 7.0-7.2 (tested 3 times) and with my 27'x52" 15,500 gal pool, it took me 5 days and 6 gallons of MA to get it down to the 70-80 level ... it's frustrating, trust me ... I thought I was never going to get below 100. Be sure to test your fill water so you know what you are in for!
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
    Jun 2011
    New Jersey
    149
    Since we are on the topic of ph and muriatic acid how often should I be adding muriatic acid to keep my ph 7.6? I mean thus far I have been adding once a week but then again I was getting bad results from Leslie's telling me my ph was ok. But either way should I be adjusting every couple of days to keep ph on level or is one a week ok ?
    Free Form Gunite Saltwater Pool, 29,000 Gallons, Jandy DEL60 Filter, Jandy AquaPure 1400 Chlorinator, Polaris 380 Cleaner, Attached HotTub.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quote Originally Posted by RafaelS
    Test your chlorine and pH often. Daily... Every other day... Wouldn't want to go much longer than that if my pH was not stable. How often to add MA A can be preference and also determined by how low you drop it. When my pH gets to 7.8, I add enough MA to get down to 7.0 -7.2. Repeat once it gets back up to 7.8. If I were only dropping it to 7.6, I would be adding every day almost! After numerous "cycles" I add MA a lot less than I did when I had a higher TA.
    ~~ Allison ~~
    Feb 2008
    Denton, TX
    5,061
    You add what you need, no matter the amount, to get your pH to 7.2 each time.
