Thread: Removit
    Removit
    Anyone try this before. Cheaper than stain-free but supposed to do the same thing. I just picked up a bottle for some brown smear like stains all over pool and on edge of steps. Says it is compatible with sanitizers and won't lower PH. I am gonna try it with some Metal-Free and see what happens
    Newbie in Hampton, Virginia
    TF-100 test kit
    18' round x52" /Sharkline Heritage /8000 gal /vinyl AGP
    Intex 2650 GPH, 1 HP, sand filter and SWG combo
    Solar cover
    Re: Removit
    Stain Free is just ascorbic acid. RemovIt is mostly citric acid mixed something that helps it form a paste. In both cases the generic chemicals are less expensive. Metal Free is not one of the sequestrants we recommend. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are significantly more effective.
    Re: Removit
    What is a better sequestrant? Also will I have to lower my chlorine with removit? It does not mention doing so. I got 2 pounds for 10 bux
    Stain remover then sequestrant or vice versa?
    TF-100 test kit
    Solar cover
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Removit
    Here's complete directions from Pool School:
    ascorbic-treatment-to-rid-pool-of-metal-stains-t2298.html
    You're done SLAMing when:
    Re: Removit
    Worked but not as well because I could not get my CL to drop quick enough. Added the removit and then the metal free after 24 hours. Significant fade of spots but I will be doing the AA treatment again soon.
    TF-100 test kit
    Solar cover
