Results 1 to 9 of 9
Thread: My SWG
    Jul 2011
    Surf City, California
    24
    My SWG
    Salt has been added several days ago. I been running the SWG 12 hours a day at 100%.
    Here is my reading:
    FC 0
    TAC 0
    Salt 2900
    CYA 90
    TA 100
    PH 7.6
    PHO 300
    I am waiting on the SWG to start making chlorine to get the FC level up. I'm Worried about the FAC/TAC still staying low. Should I shock the pool with Chlorine to give it a head start?
    25-30K Gallon Inground Pool and Spa
    DE-Filter system 60 Sq. ft
    Salt Chlorine generator
    Pebble Bottom
    Variable Speed pump
    22,542
    Re: My SWG
    You should bring the FC up to about 8 ppm with liquid. In fact you may already be too late and may have to really shock it.
    Jul 2011
    24
    Re: My SWG
    Can I used Powder chlorine such as Powder plus sold at Leslies?
    Pebble Bottom
    Variable Speed pump
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: My SWG
    You're better off using liquid chlorine or bleach. Leslies powder plus appears to be Calcium Hypo.
    Prolong use of this can cause your pool to have high amounts of calcium.
    The benefits of using liquid chlorine or bleach is you are not adding any other chemicals into your pool.
    Pool School explains more in detail: How to chlorinate
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    22,542
    Re: My SWG
    You don't list a CH number in your results so I can't say with certainty but if your CH isn't high you can use it. It adds calcium and yuo don't want that getting too high.
    Jul 2011
    24
    Re: My SWG
    I did not test for CH since my kit didn't have it. I will add liquid Chlorine. How long after shocking can I use the pool?
    Pebble Bottom
    Variable Speed pump
    22,542
    Re: My SWG
    Lets correct a little terminology. Shocking is a process, not some product you throw into the pool. You're just adding some chlorine to bring the FC up to normal range.
    Once you have the chlorine in, wait about 30 minutes before getting in.
    Jul 2011
    24
    Re: My SWG
    I have an estimated 25,000-30,000 gallon pool. I was looking at the chlorine bottle and it says 1 bottle per 10K gallons, so would putting in 2.5 bottles do the trick or should I put a little more such as 3.5 bottles?
    Pebble Bottom
    Variable Speed pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My SWG
    Use the http://poolcalculator.com/ to determine how much to put in. If it is 12.5% Sodium Hypochlorite (check bottle), and you want to get to 8ppm of FC, and the pool is 25000 gallons, the poolcalculator is giving ~200 oz needed. Since you have let it drop to 0, I might go to the suggested higher normal level of 12 ppm.
