Results 1 to 18 of 18
Thread: 12x30 intex pool too much chlorine
    Hi
    I have a 12x30 intex pool, filled it with water - didn't have any chemicals on hand at the time, used it to swim, then on the 3rd day it was turning green and slimy. Finally got some chemicals(shock) and overdid it - put in one full bag of 16oz. I bought a small test kit that tests for ph and chlorine, the chlorine of course is way too high - no suprise. Do I need to empty all the water and start over or just empty part and add fresh water (have already done that once)? I have the pump running and go out every few hours and rinse the filter out. Just wondering when it will be safe to send the kids into the pool again, it is extremely hot & humid here. Suggestions.
    Aug 2010
    Boston, MA
    176
    Re: 12x30 intex pool too much chlorine
    You should start by reading through Pool School. Important things you need:
    1. A good test kit. The TF100 is great. In the interim, test results from the pool store will be better than nothing. (FC, CC, pH, TA, CH, CYA)
    2. CYA in the water to prevent the sun from burning off all your chlorine.
    3. KEEP the chlorine level high enough at all times. 16oz of what sounds like it was probably cal-hypo is a VERY SMALL amount of chlorine.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    Thanks and yes I have been reading the pool school. We do not have a pool store near us. The pool shock label said to add 1 1/4 oz to my size pool but when that didn't yield results I just kept adding it. I don't want to let the kids in if the chlorine is too high. I bought the test kit that I could find in the store, only spent $59 on the pool, do not want to spend as much on a test kit. The bag of pool shock I used reads: All in one shock xtra - ingredients sodium dichloro-striazinetrione dihydrate 64%, alkyl dimethyl benzyl ammonium chloride 1%, other ingredients 35%, total ingredients 100% available chlorine 35%
    22,400
    Hopefully you've read the article on Seasonal/Temporary Pools.
    You've added 30 ppm CYA and 33 ppm FC. I'd switch to using bleach for chlorination now.
    What is the max your test kit reads in TC?
    If you have a Walmart nearby, some of them have a HTH 6-way drop based kit that works ok for small pools.
    To get you back swimming, take a sample of pool water and dilute it with an equal amount of chlorine free water and test the water, then double the result. I.E. your TC reads 5, multiply that by 2 and your real TC = 10. Once it gets down to 10 you can swim again. (you could actually dilute the pool water with 2 parts of chlorine free water to 1 part pool water and multiply the result by 3 but the accuracy is pretty suspect at that dilution.)
    Yes I have read the seasonal pool link, thanks.
    My test kit for chlorine reads
    3.0
    1.5
    1.0
    0.5
    0.3
    and mine is really deep yellow 3.0 or more.
    The PH reading says 6.8, 7.2, 7.6, 7.8, 8.2 and mine is in the 7.2 range.
    I can check at walmart and see if i can find the kit. Looks like this test kit is probably useless since the numbers I have on my test kit are no where near what numbers you are talking about.
    22,400
    You can do the 3:1 dilution and that'll get you to 12 ppm. I wouldn't go past 3:1 though and even then it's just a guestimate.
    You also need to test your pH once the chlorine comes back down to about 10 or less.
    A better test kit is definitely in order.
    I will run out of town today and see if I can find a better test kit. Might be back to ask more questions, thanks to everyone for their help.
    Also, I couldn't find the polyquat 60 - is this the same thing? 50% algaecide concentrate ingredients n-alkyl dimethyl benzyl ammonium chloride 49.8%, n-dialkyl methyl benzyl ammonium chloride .2%, other ingredients 50%. Or is there a brand name I should be looking for?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Walmart's return policy is great. You can tell them the test doesn't work for you and put that money toward the 6-way drop test they sell. That test doesn't go above 5ppm FC though. You will still have to use the dilution method Bama described. Get a jug of distilled water while you're there.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    I didn't get the first test kit from walmart, got it from menards. Ok so on my shopping list today is the hth 6 way test kit, distilled water, anything else I may need?
    menards is good with returns too, ours has a kiosk where you can re-print receipts.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    What is the ph?
    You might want to pick up a box of baking soda and perhaps some 20/20 mule team but without test results, it's hard to know if you'll need the mule team.
    Muriatic acid would be the other thing to consider having on hand.
    w/o test results, it's hard to say what is needed for sure.
    22,400
    If it's a long way to the store you might want to pick up some pH down and a box of 20 mule team borax. We don't know which you'll need so if it's not too far just wait till you test it to buy them.
    Also buy regular 6 percent bleach. A couple jugs to last a month or so.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Ok let me make sure I did this right before adding anything else! I took two cups pool water and put with two cups distilled water, dipped in the tester, added the chlorine drops and now it read 1-2 so that should be multipled by 2 to give me 2-4 correct? So now I will need to add bleach? How much? Kids want to swim so can I add the bleach tonight before bed and let them swim now? The ph level still looks to be at 7.2. Then if I test directly out of the pool without diluting with distilled water it looks to be 3-6. So please give me more advice - ph level stayed the same.
    22,400
    Let them swim and then add the bleach. You will need to add a little bleach every day.
    Thanks again. So if I am using the pool calculator correctly, I have a pool of 12x30 size, approximately 1,500 gallons, I input the value of anywhere from 3 to 6 and wanting the target range to be 7 I should add approximately 7 oz of bleach tonight - does that sound right? Just want to make sure I am using the chart correctly.
    22,400
    If you put 30 ppm CYA in both columns then your target is 3 to 6 so 7 would be good. If you have 3 ppm now, put the in the now column and 7 in the target column. I get that you need to add 14 oz. to bring it to 7 ppm.
