Results 1 to 9 of 9
Thread: Skimmer Weir loose
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    Skimmer Weir loose
    I own a larger inground pool with spillover spa. While my kids were playing in the pool, my son tells me that the skimmer door is broken( I was thinking what did they break now). Upon further inspection I noticed one of the bolts that holds the hinge for the weir came undone, the nut for the bolt was in the skimmer basket. The other bolt was loose and the door was turned sideways. As I looked closer, the bolts come up from under the skimmer and attach with a nut, the bolt that lost the nut fell down inside hole. Now I have water leaking through the hole that is missing the bolt.
    This seems to me like a very strange design. I'm not sure of the make or model of the skimmer(I'll have to inspect it more). I have no way of retrieving the bolt or tightening the other one from the bottom of the skimmer. I also find it strange that the water leaks through the hole, I guess it may have at one time been sealed?? This is probably an old design. The pool is about 13 years old, we bought the house last year.
    I'm going to my local pool store to see what they suggest.
    23,000 gallon inground free form pool with spillover spa, Paramount in floor auto pool cleaner, Hayward C17502 filter, Andrews Advantage Series heater, 2hp Pentair WhisperFlo 26 pump for in floor auto pool cleaner, 2hp WhisperFlo 28 pump for pool filter
    22,550
    Re: Skimmer Weir loose
    I'd try some A-B epoxy to stick it back into place and seal the hole.
    Can you post a picture of it. Others may have a better suggestion.
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    I used the A-B epoxy around the sides of the front of the skimmer by the wall to seal some leaks, it worked pretty good. I was thinking about using it on the weir, but not sure if it would hold right.
    I will try and post some pics today.
    Thanks for your input!
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    Picture from inside skimmer showing hole where bolt fell through.
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    This is a picture looking into the skimmer from the pool. I can see the bolt in the hole, but have no way of getting it.
    22,550
    You're either gonna have to glue that down or there'll be a shovel in your future! I hope you're not claustrophobic if you decide to dig?
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    Here is a picture of the hinge for the door, it looks like all one piece. I don't think the door separates from the hinge.
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    It seems like there should have been some sort of gasket to prevent the water from leaking in the holes, even with the bolts in place.
    22,550
    The bolt was probably encased under the bottom at one time.
