Results 1 to 15 of 15
Thread: Oppressive Heat!
    Oppressive Heat!
    How is everyone handling this major heat wave? Seems like it has been hot forever here in Southern Indiana! There is no end in sight either! My pool is doing pretty good since I added more stabilizer. I am adding a jug of bleach a day tho. I think that is mostly because I want to keep it toward the high side because I had a major algea battle a few weeks ago and don't want to do that again. The pool is at 90 degrees but with evaporation I should be able to add some water tonight. Enjoy summer and stay safe out there!
    PS...I LOVE BBB!
    17K gal, AG, Hayward Sandfilter, new to the BBB method.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Oppressive Heat!
    This heat wave is horrible
    Even tho we are not as hot as some, 100 w/index 110 today, it is miserable. The only way to be outside even for a few minutes is to get wet - with water!
    How people are able to work outside in this is unbelievable.
    Since I tossed my old pool thermometer, I don't know the temp.
    But, I do know it is cool and refreshing
    Stay safe out there!
    You're done SLAMing when:
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I have guys building my deck in this heat... as much as I want that deck, I do feel sorry for them. I told them they are more than welcome to jump in the pool at any time... btw, they all complimented me on how clean my water looks.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    DaneCE's Avatar
    Jul 2011
    VA
    279
    I work outside. Today I packed up at 1 O'clock in 110 heat index. Yesterday I worked until 5 PM and it was just as hot...10 hours and it was torture. I use a carb/electrolyte powder called Glyco-Peak, 3 serving in 1.5 gallons which keeps me alive. Friday my area will see 119 heat index but no work for me...I'll be headed to the VA mountains and hopefully get a few degrees of relief.
    Even in 100 degrees it's amazing how the pool is an instant rescue.
    kenandshari's Avatar
    Aug 2010
    Savannah, GA
    134
    It's just another normal summer in the south! The solar heater is off and pool was 92 at 6pm today. We may have to start running it a night to bring it back down to 85-88.
    Ken & Shari
    Savannah, GA
    16' x 40' freeform fiberglass inground (Pacific model, mfg by Tallman Pools), 23k gal, 2" plumbing throughout, Intellichlor IC-40, Easy Touch controller, Intelliflow VS 3050 pump, Pentair Clean & Clear Plus Quad Cartridge filter. 4 Jandy deck jets (3/4" plumbing), Fiberstars color changing lighting, SR Smith salt friendly diving system, Interfab Wild Ride slide, Aquasol Solar Heat (5 panels 4'x12' DIY install automated with ET) RIP Nitro Wall Climber Mar 2011-Aug 2012, Nitro is survived by a Polaris 360.
    South Central NJ
    3,192
    Anyone want to dig some replacement lines? Nice hard packed clay too! Actual temp tomorrow is expected to be 103. Add the humidity....
    I have 3 things to do tomorrow. Pick up my new glasses, seal a leaking light conduit, and throw out some stuff in the yard.
    Scott
    Owner of - PoolGuyNJ LLC
    The important thing is to do the outside things before 10 AM if at all possible, even if that means getting up super early. Then as the heat builds you can do the things that are not outdoors, if that can be managed.
    I do hope that kids on sports teams are taking a break, that sort of thing is dangerous. A child or two dies each year in Texas due to sports or similar events in excessive heat.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    It was warm in greater Los Angeles today; I set up my digital thermometer and it showed 89º in the shop this afternoon. Must have been 30-35% humidity, too.
    :-Þ
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    106 today. Just a typical summer day here in Tucson.
    chiefwej
    Mar 2011
    Lower Bucks County,PA
    65
    Yeah, but it's a dry heat 105 here today 97 at my desk-I wish it would snow
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Mar 2007
    Coastalish 'down easter'
    4,160
    Heat is good, cold is bad
    My GM said that none of the employees should be working outside today (that was nice of her, but the pools need to be cleaned/ maintained ) I spent 7 hours out in 97+--- what do I care, it's my job and I'm gonna do it (at least I didn't have to trowel any concrete or vermiculite )
    Honestly, these folks in Maine don't know how to deal with a little heatwave! (this would be a fairly standard day for Richmond, with a Bermuda High going on ) (then again, y'all down south can't handle more than 1" of snow in the winter :P )
    Luv& Luk
    -Ted
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Just remember one thing about heat......you don't have to shovel it off your driveway to get to work in the morning.
    chiefwej
    Mar 2011
    Grand Rapids, Michigan
    279
    I swapped out my Aug. week of vacation for this past week just to enjoy the pool in this heat. Hope I don't end up crying in August! Pool season is TOO short here and pool weather is never a sure thing. Two years ago the average high temp in July was 68. It was not a good season for pools!
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Apr 2011
    Somewhere on the Emerald Coast
    156
    Not too bad here on the gulf coast (FL panhandle). Temps been around 90 and humidity about 65-75. Since we have a constant breeze coming off the gulf - it's actually pleasant. Pool temp gets to about 85 during the day (partial sun) then drops to 83-84 when the sun drops below the trees casting a shadow on the water. With the breeze tonight - it actually felt cooler when I got OUT of the pool!
    Just remember to HYDRATE !! Water and/or Gatorade!!!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    Jun 2011
    Cape Girardeau, Mo
    125
    Hot, Hot , Hot here in Southeast Missouri and looks like it is going to stay that way ! Our pool stays between 84 and 88 degrees which is perfect for me anything under 84 i think is cold.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
