Thread: DE shooting back into the pool
    Yesterday, I backflushed my Pentair FNS Plus 48 for the first time (first for me), after I noticed that the water has become a little cloudy (I did not have a starting pressure measurement for the filter, as I just started to take care of the pool by myself.) I followed the instructions and everything went well until... I put ~5lb of DE powder into the skimmer (slowly) and noticed that DE is shooting back into the pool. The water became even more cloudy and the bottom has a lot of DE powder now.
    I have a technician coming tomorrow, as my first assumption was that the grid(s) failed. However, I noticed now, 24 hours after he backflush that the water is much clearer.
    Any idea why the DE came back? Can it be a one-time issue? Should I wait with the technician and see if the water is looking better tomorrow?
    Thanks!
    Guy
    ~20k gallon IG plaster pool, Pentair 3/4HP Whisperflo, Pentair FNS Plus 48 DE filter, IntelliClor IC40 Salt Generator, Pentair Legend Platinum Robotic Cleaner
    Oct 2010
    Georgia
    317
    Re: DE shooting back into the pool
    Most likely grid failure
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Jun 2010
    Glendale, CA
    513
    If you have a multiport it could be a spider gasket issue as well - either bad gasket or hung up on the mechanism allowing water to bypass the filter altogether.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
