Results 1 to 9 of 9
Thread: New Pool - Lantana, Tx
    May 2008
    Flower Mound, TX
    5
    Howdy all,
    Just getting started building a house over in Texas, and am working up estimates from contractors for the pool.
    Quick question.
    How are the Jandy product lines? The first quote has a Jandy Soft Cell with the Nature 2 mineral injector. I am having trouble finding reviews for these products, and the idea of the mineral injector sounds strange. (I have a salt cell pool now, and except for acid, it runs itself)
    I gotta say, I was a little shocked at the price. With a raised spa .. it's about 53k. I don't have color printouts of the design yet, but I will add them when I can. The bid is all high end equipment.
    It's a sizable pool - 3'6" low end, to 6 feet in the deep end. With Stonescape pebble plaster finish with the added pebble. Jandy PRO DE Filter with a heater with is a Jandy LXI 400k heater for the spa. (Jandy Stealth 2HP pump)
    Dimensions are:
    Length 32.6 feet
    Width 22 feet
    496' of decking (aggregate)
    91' of stone with 36' of rock and beam along the back side with 3 small waterfalls.
    Any comments appreciated. Will post design when I get it. 2 more bids coming in soon.
    Thanks!
    Cantose
    20x40 Vinyl IG, 1.5 HP Hayward SuperPump II, Sand Filter, Polaris 280
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: New Pool - Lantana, Tx
    Don't waste your money on a Natures 2. 53k sounds high!
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Feb 2008
    Denton, TX
    5,061
    Hello neighbor. I would seek out other bids. That is high.
    Do NOT let yourself get talked into any type of mineral system. The Nature 2 (I used to have one), the Pool Frog, and other similar systems add metals to your pool. Metals cause green hair and stains on pool surfaces. They are expensive to run and offer no benefit at all. They are only moneymakers for pool builders who sucker folks in to paying for them. Any pool builder that tries to sell you a mineral system is not one that I would do business with.
    I wish the rocks bordering my pool were all above the water line. Serious algae traps.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by anonapersona
    That is some good insight. I would imagine that folks really don't know just how much extra underwater surface area comes with that type of border. It would be tough to clear an algae bloom with that I would bet.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    Sounds high, get more bids.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    smccull's Avatar
    Apr 2010
    Allen, TX
    96
    I don't know - price sounds about right for the DFW area - you have a good sized/big pool. We had bids of 45-55k for a ~17x32 contemporary with spa, pebbletec, travertine and -about 700 sf of stamped decking. I would guess you are in the 25-30k gallon range. Same depth profile.
    PS ours was all jandy, cartridge filter (like it better than our DE in our old pool and the water is just as clear) jandy variable speed pump, heater, PDA - only water features were deck jets - 2 lights in pool 1 in spa - conventional that I replaced with LED bulbs - all 1+ year old and no problems. Might save some if you go with a lower quality builder but then I doubt it would be done before summer is over - they save money by taking the subs when they aren't busy.
    Edit: ours is closer to 18'x36'
    Steve
    Deep in the Heart......errrr HEAT of Texas
    20k gallon gunite formal
    May 2008
    Flower Mound, TX
    5
    Thanks for all the tips!
    I suspected as much which is what pushed me to ask. I think I will take up the recommendation to do a system without the Mineral 2.
    Thanks!
    Jun 2011
    Flower Mound, TX
    37
    Who's the builder. I'm right next door to you in Flower Mound, and just got my first quote today at $48k for all Jandy, 19 x 36, 605 sq ft with a 111 foot perimeter and 3'6" to 8'6". This builder also uses the Nature2 - I like him, but based on everything I've ready, it's not worth the money.
    20' x 40' / 33,000 gallon / IG / Vinyl
    200lb sand filter / 1hp pump
    4hrs full sun with about 45 min part sun before and after
