Results 1 to 7 of 7
Thread: Salt tester
    Jul 2011
    Surf City, California
    24
    Salt tester
    Has anyone use the electronic salt tester? I see it is expensive but will pay for itself in time if that is all you need. I see they use it at commercial pool suppliers to sample the salt level.
    LAMOTTE SALT TDS TEMP TRACER POCKETESTER
    25-30K Gallon Inground Pool and Spa
    DE-Filter system 60 Sq. ft
    Salt Chlorine generator
    Pebble Bottom
    Variable Speed pump
    30,415
    Re: Salt tester
    Since you only need to test your salt occasionally, I can't see how it would "pay for itself". In what way do you think it is advantageous?
    Jul 2011
    24
    Re: Salt tester
    I test my water once a week when I do maintenance on my pool. I live in Southern California so my pool is used almost all year around and with the cost of the salt strips, 10 for $14.00, I figure it will pay for itself over time. I see that most of the pool suppliers and pool techs are starting to use the electronic tester instead of the strips. I found online that the tester cost shipped will be $125.00.
    Pebble Bottom
    Variable Speed pump
    Aug 2010
    Boston, MA
    176
    Re: Salt tester
    Do you actually see so much change in the salt levels week-to-week that weekly testing is necessary? If you were testing monthly, the breakeven point would be about 7.5 years; I'd be skeptical that the tester will last that long. Pool professionals are presumably doing such tests on SOMEBODY'S water multiple times a day, so their experience doesn't really translate to someone caring for a single pool.
    Of course, if you really need the weekly tests then the payoff time is under two years and it makes more sense.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    Jul 2011
    24
    Re: Salt tester
    I was told by pool supplier to test my salt weekly. Can I get away with testing it once a month?
    Pebble Bottom
    Variable Speed pump
    Re: Salt tester
    Unless you have a huge amount of rain, or replace a lot of water, you can usually get by testing salt about twice a year.
    The electronic salt meters drift, so you need to calibrate them frequently.
    Aug 2010
    Boston, MA
    176
    Re: Salt tester
    I wonder - is the pool supplier selling the strips? If so, he has a rather obvious incentive to get you to test as often as he can, as opposed to as often as you really need to.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
