Results 1 to 7 of 7
Thread: Where can fine silt sneak through my sand filter?
    Mar 2007
    Ontario
    211
    Hello,
    When I turn on my filter a fine silt like dust shoots out the returns for about 5 to 10 seconds,then
    runs clear.
    Its not filter sand and I don't even feel like I am catching it in a skimmer sock when held in front of return.
    I don't think its a cracked lateral, as I had it apart in the spring and check very very closely.
    My question is where else could this silt be sneaking through?
    Thanks for any advice!!!
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    22,544
    Re: Where can fine silt sneak through my sand filter?
    Fine silt can get through a sand filter. You can try adding a cup of DE to the filter and see if that helps.
    30,414
    what is your FC level? It sounds like you may be growing algae inside your returns.
    Mar 2007
    Ontario
    211
    I bump it to around 5 or 6 at night my CYA is 30. I passed an overnight FC test a couple weeks ago when I first noticed ,but could check again.
    Thanks
    30,414
    Yeah, I'd take the FC up to around 10 for a few days just to see if things got better. I also suspect your pump run time could be increased a little if you're not running at least 8-10 hours daily. I would try both those things and see if the issue stopped. Post back if not.
    Mar 2007
    Ontario
    211
    Great thanks
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    I don't see that you've listed what brand filter that you have, but you might have a problem similar to the one I described in this thread -
    http://www.troublefreepool.com/testi...t19811-20.html
    Good Luck, and best wishes
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
