Page 1 of 4 1234 LastLast
Results 1 to 20 of 73
Thread: Desperately need advice. (Day 9--We have a clear pool now!)
    Jul 2011
    Greer, SC
    43
    I've been trying to clean up the pool for weeks. First the pump wasn't working and we fixed it but then the pipe broke. Now that the pump is fixed and we put a lot of chlorine granules in it and we have a chlorine dispenser too. Since I scooped out tons of leaves from the bottom the water looks much better but it's still kinda green and very cloudy.
    I only have a ph and chlorine test kit. The chlorine level was very high 2 days ago when we put the granules in but now it dropped to below 1 again and I used a lot of ph up but the ph is never higher than 6.8. Now we've spent probably more than $200 on chemicals and we can't really afford to waste any more money. The pool looks like this right now(it used to be completely black) and I'm hoping that there's an inexpensive way to clear it up before the summer ends! Any advice is appreciated!
    1) 12000 gallons
    2) Hayward Sand Filter S200
    3) In-ground
    4) vinyl
    5) size of pump and the size (flow rate) of the filter unknown
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Desperately need advice. Green pool won't clear up!
    You need to read shocking your pool in pool school.....buy a LOT of 6% bleach..............and post us up some pool store test results to start from.
    nathanwitte's Avatar
    Jun 2011
    Valparaiso, Indiana
    14
    Others with more experience are probably already typing a response, but my guess is that their answer will be:
    Get a good test kit, find out your CYA level, use liquid chlorine/bleach, and remove any solids at the bottom.
    If its taking a long time to shock the water clear, you probably aren't getting the chlorine level high enough to stay ahead of the algae growth. If you don't get and stay ahead of the algae, your chlorine is wasted.
    The chlorine level needed is dependent on your CYA levels. See http://www.troublefreepool.com/pool-...ya_chart_shock
    Good luck! My pool was black when I opened this year and is now clear thanks to advice I found on trouble free pools.
    I have the same filter as you. A tip for when your pool clears up: when vacuuming the dead algae off the bottom you'll want to vacuum to waste or else some amount of it will pass through the filter and return to the pool. You'll only want to vacuum to waste for the worst spots and work quick as you can loose a lot of water.
    16x32 IG 25,000 gal Vinyl, 1.5 HP Hayward Superpump, Hayward S200 Sand Filter
    Aug 2010
    Dallas, TX
    4,052
    Yep, that's it!
    Read up on the shock process here:
    pool-school/shocking_your_pool
    You are going to need the FAS/DPD chlorine test kit at minimum to go through the process.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You need a good test kit and to read the section on shocking and clearing a swamp. Without a good test kit you are flying blind and not getting the best benefit for all those chemicals you have added. Think of this as a war against algae, and the chlorine level is your number of troops. If you dump a whole lot in and don't keep them resupplied they get wiped out and soon your back to the starting point, a good test kit like the TF test TF-100 will let you know where your standing in this war, or at least when more troops are needed. Putting too much in wastes chlorine also and can cause damage to your pool liner, etc. I know a good test kit is a big investment at this point, if you can't afford the TF-100 they also offer a smaller TF-50, but I think everyone here will tell you these type of kits will pay for themselves quickly in time and effort saved as well as in dollars saved on wasted chemicals.
    Ike.
    Jul 2011
    Greer, SC
    43
    Quote Originally Posted by woodyp
    Thanks! I've been reading stuff in the pool school section and doing research on the web. I know I need a good kit to know the cya level. Our local walmarts don't have the 6 way kit and I'll probably need to order online. In the mean time is there anything I can do to improve it? Should I keep the dispenser in the pool? I'm afraid that'll add more cya and keep lowering the ph... Adding ph up doesn't bring up the ph at all.
    1) 12000 gallons
    3) In-ground
    4) vinyl
    May 2009
    NC
    136
    Yeah, what they said.
    You definately need a good test kit, it's impossible to properly shock your pool without it. Mine is the best investment I've made in the pool since we had it installed. It's worth every cent!
    Read Pool School - How to Shock Your Pool and follow what it says, and it WILL happen. Take a look at how my pool looked at the beginning of the season....
    http://www.troublefreepool.com/openi...mm-t32363.html
    ETA: I did end up having metals, so had to use some sequestrant for that, but you can see from the pictures what just lots of plain old 6% bleach did for our pool (and some muratic acid since my pH was high at the very beginning). And brushing and vacumming.
    24' Round 52" High AG, Waterway 125 SF Pro Clean 2HP, 2 SPD Cartridge Filter
    Pool Rover Jr. /TF-100 Test Kit/ BBB - Ex Baqua User
    Aug 2010
    Dallas, TX
    4,052
    You need to be able to measure chlorine at shock level also, and the WalMart kits won't do that either. Consider the TF-100 from http://tftestkits.net
    Jul 2011
    Greer, SC
    43
    Quote Originally Posted by nathanwitte
    Thanks so much for the reply! I'm thinking of switching to bleach after I read the posts in the pool school section. And we need a new vacuum cuz the pool is in a bad condition and everything seems to be broken...
    1) 12000 gallons
    3) In-ground
    4) vinyl
    Jul 2011
    Greer, SC
    43
    Quote Originally Posted by RobbieH
    Yep, that's it!
    yeah we wasted too much money and I'm waiting to get paid. Do you think this one is gonna work for now?
    http://www.amazon.com/Aquacheck-Select- ... roduct_top
    1) 12000 gallons
    3) In-ground
    4) vinyl
    Aug 2010
    Dallas, TX
    4,052
    Test strips are not accurate, and won't measure chlorine high enough for the shock process.
    Jul 2011
    Greer, SC
    43
    Quote Originally Posted by Isaac-1
    Ike.
    Thanks so much! I'll check out the kits.
    1) 12000 gallons
    3) In-ground
    4) vinyl
    Jul 2011
    Greer, SC
    43
    Quote Originally Posted by stephanie4136
    thanks for the link! that's very encouraging!
    1) 12000 gallons
    3) In-ground
    4) vinyl
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I had some friends that were using test strips to try and clear their algae problem...wasn't until we started using my TF-100 that we were able to clear it up. They spent 4 weeks trying with strips first, then 1.5 weeks getting it done with the tf-100 reagents.
    Jun 2010
    Glendale, CA
    513
    The TF-100 at TFTeskits.net is going to be the best value for a quality kit (more tests per $)
    Your PH problem is most likely caused by lots of trichlor use - pucks. They are acidic and will push PH down. The PH up probably appears to do nothing because the test bottoms out at 6.8 - so your true PH is quite a bit lower. That's really not good.
    If you haven't already started shocking I would wait for the test kit. Your pool is already far gone so it wont get worse. The best course of action may be to drain because of CYA - so no need to waste chems until you know. The more water you drain the more algae you drain the less chlorine you'll need to clean it up.
    Once your pool is back from the dead you can expect to spend about $20/mo on chemicals, check and add chlorine daily or every other day and probably add some acid once a week (when you stop with the Trichlor your PH drift up by default not down).
    Good luck
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You see a lot of advice around here about use of acid, acid use depends a lot of your location, fill water, type of dust, etc. that may be blown into the pool, etc. I have an indoor pool surrounded by sliding glass doors which limits amounts of dust and dirt, and my pH is very stable, for ease of use I tend to use dry acid, but in the past when using Muriatic acid my consumption would be about one quart per year, or so.
    Jul 2011
    Greer, SC
    43
    Quote Originally Posted by lightingguy
    Good luck
    Thanks! I'll get the kit then. If I drain some of the water and put a hose there to add water at the same time, will it help clearing it up?
    1) 12000 gallons
    3) In-ground
    4) vinyl
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would wait until you get the kit, being so close them if you order today, you might have the kit in hand by the weekend.
    Ike
    Jun 2010
    Glendale, CA
    513
    Quote Originally Posted by Snowball
    Not really. Algae will grow until it reaches a certain "density" in the water. If you drain some water and replace without immediately shocking it you wont get much benefit on the algae side. You get rid of some algae but then provide the remaining algae clean water to grow into.
    If it were me I would wait for the kit, post the results and then gather all your supplies before hitting it hard.
    I would get that PH up to 7 or so now.
  20. Back To Top    #20
    May 2011
    Clearwater, FL.
    446
    This is the way to a sparkly and trouble free pool!
    TF-100 kit, lots of bleach or liquid chlorine, possible partial drain, some elbow grease, read pool school daily and some POP! (Pool Owner Patience)
    A lot of our pools were just like yours, we did it, yours will be no different!
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
