Thread: Too much free chlorine after shock
    Jul 2011
    Canton, MI
    47
    18,400 gallon pool. I added some bleach to shock the pool (green algae just starting to grow on floor of pool), however I added too much. I just checked the free chlorine and it was at 30ppm (should be around 16-20 for shocking). CC is 0.5, and CYA is around 47. It's supposed to be very hot and sunny for the next couple of days. Will the free chlorine lower on it's own, or should I lower it with chemicals? Thanks!!!!
    17,500 gallons, Vinyl, Above ground, Hayward Sand filter, Hayward 1.5hp pump
    Aug 2010
    Dallas, TX
    4,052
    Re: Too much free chlorine after shock
    It will come down very fast on its own. In fact, if you have algae, you will probably be adding more bleach soon!
    Jul 2011
    Canton, MI
    47
    should the level come down fast enough to swim in it tomorrow or the next day?
    Aug 2010
    Dallas, TX
    4,052
    Remember, shocking is a process, not a one-time addition. You need to hold shock level until you can pass the overnight loss test, your CC is less than .5, and the pool is clear.
    pool-school/shocking_your_pool
    Jul 2011
    Canton, MI
    47
    Sounds good, thanks for you help!
    22,550
    If you are done shocking the FC will come down pretty fast and you can swim up to your shock level. Which is 20 for a CYA of 50.
