Thread: SWG Question.
    Jul 2011
    Maryland
    1
    SWG Question.
    Hello everyone!
    I have Jandy Aqualink RS system with AquaPure APURE1400 SWG.
    My question is when does SWG makes chlorine during pump cycle?
    In other words, my pump is programmed and runs 13 hrs daily (7am-8pm).
    AquaPure is set to 30% chlorine production out of that 13 hrs. But when, during those 13 hrs cycle, does it generate chlorine? Does it do it in several intervals or as soon as the pump starts at 7am? And what happens when pump stopped manually and then re-started, does the SWG start over with 30%?
    Please help me understand.
    23K gallons IG pool; Medium grey plaster; Jandy DE filter 48sf; Jandy 1.5hp pump + Jandy 1.0hp waterfall pump.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: SWG Question.
    The SWG unit I own seems to makes chlorine as soon as the units control box is powered on.
    Once the units control box is powered off (regardless if it's automatic or manual) it stops making chlorine.
    But I don't watch it every day to know if it's on or off in intervals.
    I've noticed it does not make it while it's testing levels.
    I believe most SWG's will resume production at the last % it was set to.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Re: SWG Question.
    There are a couple of different ways it can work, but the most common approach is that the SWG is on for the percentage set on the control panel minutes out of every 100 minutes. Most brands remember where they were in the cycle and simply pick up where they left off. The length of the cycle also varies somewhat from brand to brand, an hour, 100 minutes, two hours, and so on.
    There are just a few models that run the entire time the pump is on and vary their output, but that is really quite rare.
    May 2011
    Sacramento, Ca
    64
    Re: SWG Question.
    Quote Originally Posted by marik08
    I have spent a fair amount of time fiddling with my Jandy 1400. The % I believe is roughly how long out of an hour or maybe 100 minutes the unit produces chlorine. If you watch the LED lights, it will give you an idea. When the pump first turns on, the Jandy waits a bit before it starts producing chlorin (green flow light, green cell on light). If you check back after awhile, sometime the "cell resting light" is on or the "cell reversing" light is on. Basically I think when the green "cell on" light is lit, it is producing chlorine. I have my unit set at 75% and run it for 5 hours a day. The "cell on" light is on alot, but some of the time the "cell resting" light is on.
    Hope that helps.
    30,000 gallon in ground pool, Jandy 1400 SWG, Jandy valves and controls, Sta rite cartridge filter, Just added solar panels and Starite Inellipro variable speed pump
    I spent a lot of money on drag racing, good whiskey, and expensive cigars. The rest of my money I just wasted.
