Results 1 to 9 of 9
Thread: is this setup a good deal
    22,551
    Re: is this setup a good deal
    If it works, I'd say $250 would be a good price. If it was moved with sand in it, the laterals and center pipe will most likely have to be replaced and that will make it worth less.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Bama,
    Could you expand on this? Do they crack?
    22,551
    If those filters are moved with the sand in them the sand shifts and cracks the laterals and sometimes the center pipe. They're designed to be static and not to withstand pressure from the shifting sands, as it were.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    So rolling a sand filter on it's side (while filled with sand) might be a problem? Oh..Oh
    22,551
    I'd say you'd be VERY lucky if it wasn't a problem.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It might be...it was my spare filter, that was rolled over to my neighbors...and it took a long time on their small pool to clear it up. This could be the reason it was "sub-optimal"...
    Seems like I have enough reason to open it up and check for damage.
    now im lost about this as well. so when i go look at used filter and if they have sand in them i should look to see if the pipe is cracked inside. never had a sand filter so this is very new to me.
    the one i posted earlier she still hasn't got back to me and i thought it was still in the box as what my friend said to me but i looked her add up and she said it was used for a month
    http://norfolk.craigslist.org/for/2501950501.html
    then i came across this tonight the guy is selling everything pool and all for 200 figured i would get it all give pool away and still have a good deal. http://norfolk.craigslist.org/for/2504612231.html
    so bama when going to look at new setups what should i ask? things like did you move the filter with the sand in it would that be the main question and where do i look for damage if they have been moved
    22,551
    The big thing is if they moved the filter with the sand in it. If they did that's a red flag. It's hard to inspect the internals. so you need to negotiate the price basd on that.
