Results 1 to 7 of 7
Thread: CYA keeps going up
    CYA keeps going up
    So I have been using the BBB method for almost two weeks now... My pool is looking great. I am using the TFTest kit. What is strange is it seems like my CYA is going up. It was 90, I drained, refilled, it was at 50, moved up to 65 and today it is at 90?
    FC 8.5
    CC 3.5
    TC 12
    PH 7.5
    T/A 110
    CYA 90
    Tulsa, Oklahoma
    13,000
    SAND
    AG
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: CYA keeps going up
    You have not used solid chlorine at all? No shock products or tablets?
    What about those products before the drain? How close to the drain were they used? With CYA not always showing up immediately on tests, perhaps your pool's level was higher than 110 when you drained and it is only showing up on the test now?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    I haven't used any since I switched to BBB. But before that i put in a bunch of powder shock... I used floater tabs up to about a week ago but I stopped using them...
    Tulsa, Oklahoma
    13,000
    SAND
    AG
    Jun 2010
    Glendale, CA
    513
    Your cc is 3.5? If that's true then you have some sort of algae problem.
    The CYA test really is testing cloudiness - right? Perhaps your water is much cloudier now and that combined in the test makes it appear that CYA has gone way up? Obviously I'm guessing - but that CC does not look good
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Quote Originally Posted by TulsaMary
    That very well could be the reason. I would hazard a guess that now, if you do not put anything into the pool that contains CYA that it will stop drifting up. You'll need another drain though. Rats!
    My dad's spa was refilled two weeks ago due to high CYA. He didn't listen too well (so strange... my kid's listeners are broken and so are my dad's. hmmmm...) and proceeded to dump enough dichlor into his water to raise CYA up to 110+ in just two weeks. Yesterday he had to drain the whole thing yet again. It rises fast.
    For every 10ppm chlorine from tablets, CYA rises 6ppm. 90-60=30ppm. 6 goes into 30 5 times. Pucks for a week could have easily added 50ppm chlorine to the pool.
    That's so crazy... I'll have to wait on a drain for a bit... I hope I don't get into any trouble... So does the CYA eventually wear down?
    Tulsa, Oklahoma
    13,000
    SAND
    AG
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    No, and evaporation won't change it either. Water will evaporate but CYA stays. Splash out and refilling might lower it a ppm or few but nothing major. Drain and refill is the way to lower CYA or you could look into reverse osmosis which will take everything out of your pool except water.
