Thread: Krystal Clear 637R water flow
    We have the 637R filter system hooked to a salt water system for our above ground pool and we are having major issues with water flow coming from the 637R. If we change the filter it works fine for a little while but after a few hours the salt water system gives us a "Low water flow" warning. We are going through a new filter every couple of days just to get it to work half correctly. Has anyone gone through this issue or should we just get a new filter system all together?
    Sam
    22,544
    Re: Krystal Clear 637R water flow
    You most likely have something going on in the water.
    Do you have a set of test results you can post?
    Also, what does the water look like?
