Thread: TA of 300?
    May 2009
    Mn
    198
    TA of 300?
    Ok just got my test kit. Checking water and the first tests were going well.
    borate 30
    Ph 7.5
    Tc 5
    Cya less than 20...not sure where it is going. Using pucks and have already added 3lbs. Have another pound dissolving.
    But my TA test was 300. Could that really be possible? Pool store had me at 195 yesterday down from 240.
    I did add 10 1" pucks after pool store visit and a pound of borax since that seems to be disaapearing too. They had my borate at 80 but I knew that was not possible since it was 30 two days before. I used 5lbs of dry acid to reduce the 7.8 ph and TA yesterday.
    Thanks for the help. BBB has been working so far, just the TA I can't handle.
    It is hot and I know some of my chemicals could be lost to backwashing, but would that raise TA?
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Aug 2010
    Boston, MA
    176
    Re: TA of 300?
    Test your fill water. Sometimes what comes out of the tap is already really high TA.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    May 2009
    Mn
    198
    Re: TA of 300?
    Yep, knew it was 240 from the tap but we have not put in any water sine the initial fill. Just not sure how it can jump so high when we were on the way down.
    30,432
    Re: TA of 300?
    With brand new reagent, the TA test is often skewed by static electricity producing drops that are too small as you count the R-0009.
    If you take a damp cloth and wipe the dropper tip every few drops, the issue goes away. I'm not saying for sure that is the issue but it sounds like it. That static usually goes away in a couple of weeks.
    May 2009
    Mn
    198
    Re: TA of 300?
    I was wiping the tip, but I will give it time to "settle" down. Thanks for the feedback.
