Thread: Stinkyfish
    Aug 2007
    Bellflower Ca
    24
    Stinkyfish
    Hello everyone and Happy New Year. Don't let the name scare you. I like to fish and I also have a saltwater aquairium at home. I'm tired of getting getting told I need something new to put in my pool everytime I go to the pool store. I ordered the TF test kit and it should arrive soon. Thank you for a great site. Don
    Don
    12,000g gunite w/ 8'x5' spa, 2 waterfalls, mini pebble,3 Whisperflo pumps, Pentair 4060 DE filter, Intellichor IC20 SWG, MPULSE 3000 Water Treatment System,Sta-Rite gas heater, Kreepy Krauly pool sweep, TF-100 Test Kit.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Stinkyfish
    Quote Originally Posted by Stinkyfish
    Hi Don, welcome to the forum. You are on track to making your pool care simpler. With the test kit and a little understanding, you'll KNOW what your pool needs and why it needs it. You'll probably pay for the kit in savings in the first 6 months, and you'll spend less time taking care of the pool.
    Guest
    If you have a salt aquarium then water testing should not be a problem for you (been keeping salt and reef tanks since the '70s myself). In fact, almost all of the tests are identical (pH, CH, TA--which is called carbonate hardness in aquarium testing).
    As soon as the kit arrives post a set of test results so we can pick them apart!
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
