Thread: Intex 633t pump and filter question
    Okay, I have the intex 633t pump and it works great. It has awesome pressure as well as suction. My question is as follows, how long should the filters last? This pump uses the "B" filters and they are lasting a day at the most.
    We previously had a 635 pump and it was terrible so we bought this bigger pump. The "A" filters seemed to last more then a week but for some reason these bigger filters don't last at all.
    If I pull the filter out and spray it off really good it will last for the rest of the day. I can tell it's the filter because I will go out to check the pressure of the pump and it is way down so I will pull the filter out and clean it or replace it and the pump works great again, but after a few hours of the pump working really well it will start really struggling again, If I replace the filter then the pump starts working great again.
    Obviously at $10 a filter I can't replace it every day.
    Thanks
    FL_Lender
    Pool size: 8000 gal
    Pool age: Over 20 yrs old
    Pool filter: Cartridge
    Pool type: IG, Plaster, non-SWG
    Pool shape: Oasis
    Re: Intex 633t pump and filter question
    Update: looks like the 633 has died. We have a new 635 and I have installed that but it doesn't come close to pushing enough water. Anyone have a 633 they want to get rid of?
    FL_Lender
    Pool size: 8000 gal
    Pool shape: Oasis
    Quote Originally Posted by jakecarey
    Thanks
    We are having the same problem. Only had this pump 3 weeks.
    26,500 Gal, Vinyl, Sand Filter, Haywood SWG, Automatic Cover, OHIO
    Update: bought a new 633 pump, unfortunately it didn't work well either. I finally figured out that the strainer, behind the skimmer basket hose that is attached to the side of the pool, was completely clogged with hair and trash. I cleaned that off and now it pumps like a champ. New problem, the pool ring got a hole in it, deflated, and caused the pool to completely drain over night. Problem fixed and it is refilling right now.
    FL_Lender
    Pool size: 8000 gal
    Pool shape: Oasis
