Thread: Master pool pop up system
    swimmingfool's Avatar
    Nov 2010
    Nokomis, Florida
    46
    Hello everyone. I have a masterpool 6 head in floor pop up system. One of the heads broke off. I am waiting on a replacement. It could take a few days and at the moment there's just a hole where the head used to be. Of course water shoots out of it when it rotates to that pop up. I was wondering if the pool would leak with the hole exposed like that?
    using the BBB with liquid Chlorine 10.5% for 5 yrs.
    inground 28 X 14 ft. 14,700 gallon pool. Masterpool 8 port floor popup system
    Replastered w/Krystal Krete 09/23/2015
    Pentair 100 sq. Ft. Cartridge Filter - 1 hp Super Flo pump - IC20 Saltwater system.
    TF-100 test kit and the Taylor K1000
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Master pool pop up system
    Nope, it will be fine. It's just missing the nozzle now, so as long as it's not blasting water out of the pool I wouldn't worry at all about it.
    Nov 2010
    Nokomis, Florida
    46
    thank you for your answer.
