HELP: read aquachek test strips
May 18, 2011
10
Hi,
can someone please help me to read this test strip.
chlorine, ALK, CYC is look fine and I am NOT sure about PH. is the ph too high? i couldn't tell look at the strip
note: after swim my eyes is red for about 5 minutes,
Thanks
Homer
Those strips are useless they always read an off the chart color on the ph. You really need a proper test kit ..it is a requirement to properly take care of a pool it will pay for itself in a very short time !
With a proper test kit your in charge of your pool!
Without one the pool is in charge and will win everytime and drive you crazy trying to fix it!
I read that ph at ~7.5, 7.6 maybe.
But I don't trust it. Strips will foul you up every time. Been there done that... Firm believer in a good test kit now. They can give you a general idea but I would never adjust chemicals using them again.
DO NOT trust the CYA reading on that. It is never even close to accurate.
Looks like 6.8 - 7.2 to me.
Are you seeing a problem? Three different people see three different values. I've used several different pH tests and the K-1000 test is the best I've seen as far as being able to tell the pH accurately.
You really should consider ordering a good test kit.
