Results 1 to 8 of 8
Thread: HELP: read aquachek test strips
    Hi,
    can someone please help me to read this test strip.
    chlorine, ALK, CYC is look fine and I am NOT sure about PH. is the ph too high? i couldn't tell look at the strip
    note: after swim my eyes is red for about 5 minutes,
    Thanks
    Homer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: HELP: read aquachek test strips
    Looks high to me. But strips are not very accurate.
    Jun 2011
    Cape Girardeau, Mo
    125
    Those strips are useless they always read an off the chart color on the ph. You really need a proper test kit ..it is a requirement to properly take care of a pool it will pay for itself in a very short time !
    With a proper test kit your in charge of your pool!
    Without one the pool is in charge and will win everytime and drive you crazy trying to fix it!
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I read that ph at ~7.5, 7.6 maybe.
    But I don't trust it. Strips will foul you up every time. Been there done that... Firm believer in a good test kit now. They can give you a general idea but I would never adjust chemicals using them again.
    DO NOT trust the CYA reading on that. It is never even close to accurate.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    22,553
    Looks like 6.8 - 7.2 to me.
    Are you seeing a problem? Three different people see three different values. I've used several different pH tests and the K-1000 test is the best I've seen as far as being able to tell the pH accurately.
    You really should consider ordering a good test kit.
    Aug 2010
    Boston, MA
    176
    And to add another example, I read it as 8.4. So yeah, depending on who reads it it could be anywhere on the scale.
    The only function of strips is removal of green paper from your wallet.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    Many thanks for replied...
    The water is clear, i can see one side to another. The only problem is after swim my eyes very red for about 5 minutes...
    Aug 2010
    Boston, MA
    176
    Which suggests that it is indeed off, though depending on which result you believe it's unclear which way you need to move it.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
