Results 1 to 10 of 10
Thread: First test
    Jul 2011
    Webster,Wi
    62
    First test
    Did my first test with the TF-100 and here are the results: ph 8.2, TA 120, TC .5, FC 1 and CYA 0. The water is crystal clear, what do I need to work on first?
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    Jun 2010
    Glendale, CA
    513
    Re: First test
    Without CYA in the water your SWG can't keep up with the chlorine needs of your pool - the sun breaks the chlorine down as quickly as the SWG makes it. (This is assuming the salt level in your pool is correct for your SWG)
    Immediate things to work on :
    1) add CYA to 50ppm to start
    2) lower you PH to 7.2 ish with acid
    3) I would manually add chlorine up to your target level until your SWG is holding it
    Longer term -
    Your TA is a bit high. This combined with your SWG is going to make your PH tend to rise - possibly quickly. As you add acid to lower your PH you will hopefully be lowering your TA as well.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: Re: First test
    Quote Originally Posted by MK1985
    Might want to double check your chlorine. TC cannot be less than FC. You need to be very certain you have FC, CC, and TC correct when posting or you will get inaccurate information.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Jul 2011
    Webster,Wi
    62
    Re: First test
    Was alittle confused with that test but the ph and cya tests were accurate as best I could tell. I added stabilizer and dry acid going by pool calc readings, how long before I should test again? Also when adding dry chemicals it said on the container to add to the skimmer, I spread it out in the pool and brushed it for awhile, is it ok to put it in the skimmer?
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: First test
    You need chlorine.
    ~~ Allison ~~
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: First test
    pH can be tested within the hour, as long as you mixed it well. If you have any doubts, one lap around the pool with the brush will erase them.
    Give the stabilizer a week to show up on the test; save your reagent, it won't do any good to test any sooner.
    And you need chlorine, now. Or your next thread will be one of those "green pool help!" threads.
    May 2011
    Clearwater, FL.
    446
    Re: First test
    Hi MK1985 and welcome to TFP!
    The TF-100 kit works very well.
    Use the vial with the white Chlorine sticker on it, fill to 10ml of pool water, use 1 heaping full of R-0871 DPD Powder, swirl well, should turn pink if you have chlorine, now add drops of R-0871 Reagent, each drop is .5 chlorine, swirling as you go, add drops until sample turns from pink to clear, if you went clear with 6 drops, your FC (Free Chlorine) reading would be 3.
    Now add 5 drops of R-0003 Reagent, swirl to mix, if you have any CC (Combined Chlorine) it will turn back to some color of pink, if it does, add drops of R-0871 Reagent, swirling as you go and count drops to get back to clear, just as before each drop counts for .5, if you use 2 drops then you CC reading would be 1.
    To get your TC (Total Chlorine) you add FC+CC= TC, in this example your readings would be:
    FC 3
    CC 1
    TC 4
    If your testing of FC was correct at .5, with a estimate of 6800 gallons of your pool size, the pool calculator said to add 78 oz. of 6% bleach to reach a target of 6 ppm chlorine for a CYA of 50 ppm.
    I hope this helps you understand how to use this TF-100 kit and apply the results to the pool calculator to get the added amount of chlorine in your pool.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jul 2011
    Webster,Wi
    62
    Re: First test
    It was hard to grasp everything without having the test kit in hand but now that I have it and with doing some testing it will come. Diffinately will be adding some bleach today and will do another test tonight. I still need an answer about adding any type of chemicals directly to the skimmer, is it a good or bad idea?
    Richard320's Avatar
    Jan 2010
    19,073
    Re: First test
    The only thing I add to the skimmer is diatomaceous earth.
    If you add dry acid to the skimmer, it could clump somewhere in the plumbing and etch something. Like the heater.
    Stabilizer is best added by tying it in an old sock or nylon and hanging it in front of a return jet.
    Jun 2010
    Glendale, CA
    513
    Re: First test
    The only thing you would ever want to add to a skimmer are things that dissolve slowly - and even then be careful. These chemicals are meant to be diluted in thousands of gallons of pool water and putting them in the skimmer leaves them concentrated in a confined space. Also many pool chemicals are reactive with each other - so never put more than 1 chemical in the skimmer.
