Results 1 to 10 of 10
Thread: PH How Low How Long
    PH How Low How Long
    First the numbers
    FC 12
    CC 13
    PH 6.8
    TA 50
    CYA 60
    CH190
    Borates 30-50
    Temp 82F
    Grey Plaster Pool with substantial calcium on surfaces. I've had my PH at +or- 7.0 for about a week now after introducing borates and I can already see an improvement in the surface. Wondering how long I can flirt with 7.0 and whether to introduce a sequestering agent at this insane FC level?
    Re: PH How Low How Long
    Forgot to add CSI is -.80 ATM...
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You don't need a sequestering agent (for calcium, right?).
    I think you're being way too hard on your finish. Patience is key for removing scale; keeping CSI at maybe -0.4 or so and brushing regularly will take care of it....eventually.
    If you have a heater (heat exchanger), then you should definitely get the pH up to at least 7.2. Even without the heat exchanger, you don't want to be too low. You should be on the pH scale to make sure that the pH is not lower than you think.
    How did you get so much scale in the first place?
    Support the site
    got the scale from 8.4 ph all winter LOL LAzy me.... I thought the caltreat was touted as good stuff?
    oh and High TA too. finally getting serious before I ruin my plaster...
    F
    30,403
    Well, I will go out on a small limb and say that, as long as it is VERY carefully monitored, a pH of 6.8 is fine because you are trying to get something done...get rid of the scale.
    I seem to remember from the old PF about a pH of 6.8 being safe but the problem is it is difficult to tell when you go below that because that's as low as the comparator is marked.
    Since you now seem to be pH conscious and willing to monitor it carefully, I would suggest bringing it down to 6.8 by color and then bringing it up just ever so slightly so it is just a little darker than the 7.0 block.
    Anything lighter than the 6.8 block would be not good. The end result should be a distinct increase in the speed at which your scale goes back into solution.
    I should add that while I would comfortably do that if I was in your situation, others on the forum might not.
    Of course, it would be prudent to remove any metal ladders, rails, etc. and bypass the heater if you have one.
    As a last thought, I seem to remember one of Taylor's comparator blocks that goes down to 6.6.....anyone else remember seeing that?
    EDIT: I found this....I have never seen or heard it mentioned on the forum.....want to be the guinea pig?
    K-1285-4 Midget Comparator, pH (bromthymol blue), 6.0-7.4 (It's list price is right @ $60.00!!!)
    Just got a Taylor FAS DPD. It goes down to 7.0 so I'll prob hover there or a tic higher so I dont have to bypass the heater. Any thoughts on something to help? Caltreat or ???
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: Re: PH How Low How Long
    Quote Originally Posted by poolvibe
    First the numbers
    FC 12
    CC 13
    PH 6.8
    TA 50
    CYA 60
    CH190
    Borates 30-50
    Temp 82F
    If that is really your CC, you need to shock. Even if that is your TC and your CC is 1, you might want to consider shocking, retest to see if it is a testing error, or at least be aware it could mean an algae bloom is coming. I am not quite sure why your FC is 12 either unless there is a backstory. That is higher than needed for target FC but not high enough for shock FC.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Lol yeah Cc is 1. Me and math.
