Results 1 to 14 of 14
Thread: how do you pour bleach without it splashing?
    gary
    thanks
    gary
    24ft x 54" aquasphere mission agp, cartridge filter, 1.5 hp hayward, TF-100, BBB method, pool install July 2010
    South Central NJ
    3,192
    Re: how do you pour bleach without it splashing?
    Slowly and near the pool surface, away from the edge.
    Scott
    Owner of - PoolGuyNJ LLC
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The jugs of bleach I am using now come with a peel off tab under the cap, I generally just punch a couple of small holes in the tab with a key and let it slowly dribble in above the return fitting.
    Ike
    May 2009
    Seminole, FL
    71
    We have the big 2.5 gallon ones here in florida.. I submerge the container in the water so the spout is right at the water level and pour -that seems to help.
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    Feb 2008
    Denton, TX
    5,061
    Apparently, I don't pour it without splashing it. Take a look at many of my clothing articles if you don't believe me.
    Jun 2011
    NW Florida
    57
    mine are 15 gallon barrels- I get splashed sometimes. Safety glasses are essential.
    Commercial,100 K, Liquid chlorine, Indoor, Heated to 86 with Jandy Lite 2 gas heater, High-Rate Sand Triton TR-100 filters (3), 7.5 HP pump motor, IG, Plaster.
    Jesus is my Lifeguard!
    Aug 2007
    near the swamp
    806
    Quote Originally Posted by Crimson
    This.
    When using the larger jugs (2.5 gallons and up), I use a length of Polyethylene tubing (about 1/2 to 5/8 inch ID) to siphon the bleach out of the jug into the water. Available at most hardware stores by the foot.
    1) Fill the tubing with water by submerging the tubing under water and put your finger over one end.
    2) Put the other end in the jug.
    3) Put the end with your finger under water and remove your finger.
    4) When the correct amount of bleach has been dispensed, pull the tubing out of the liquid chlorine to allow the tubing to clear.
    5) Rinse the tubing in the pool water so that no bleach is left in the tubing.
    Warning: Do not suck on the tubing to get the siphon started.
    Example
    When pouring from a bleach container, be careful not to pour fast enough to trap air. As long as you pour slowly, then there will be a smooth steady stream of bleach. The bleach makers need to make their top opening larger. Their bottle design is a bad design.
    Support the site
    When pouring small amounts (1-2 quarts), I first pour into a measuring cup, and them from there into the pool. No splashing. I do like JamesW's suggestion, though.
    16x24 oval (12500 gallon) in-ground vinyl Doughboy.
    Pump: Power Pak III 1 HP
    Filter: Sequel II DE
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I learned this year at TFP how to float the bottle. It makes the pouring real close to the water, the bottle is not heavy cuz it's floating, and then I float the measuring cup as well, just let the water coming into the cup push the bleach out slowly.
    I actually enjoy watching it float away now, and no splashing ever occurs. It's way more fun at night w/pool light on than it is during the day.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2010
    England, UK
    156
    This was exactly what I needed to know today!
    The only way I can buy liquid chlorine locally is in 25 litre containers (about 6.5 US gallons.)
    I can lift a 10 litre/2.5 gallon container, and use the pool to take the weight of the container when pouring. I can't see this working with the larger containers, they're just too big.
    With the siphon method, how do you know how much you are putting in the pool?
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    Quote Originally Posted by loop_pea
    If the container is translucent, then you can tell how much you have used. If it is opaque, then you have to estimate based on experience or use some sort of container to siphon into.
    I can usually estimate well enough because the amount needed does not need to be exact. However, if I want to be more exact, then I siphon into a 5 gallon bucket and then pour from the bucket.
    You could also use a scale to weigh the container and use that as a guide. The liquid chlorine weighs about 10 pounds per gallon or 2.5 pounds per quart.
    Support the site
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by 257WbyMag
    um, ditto,
    I would love to be able to float the bottle, but floating a bottle in an IG pool involves the back and knees and balance
    JamesW, what a neat idea and I especially like the directions..... and warning !
    You're done SLAMing when:
    The tubing comes from a roll, so it will have some curl to it. Sometimes that can be a problem when trying to get it to reach the bottom of a container of liquid chlorine. There are a few things you can do.
    First, store the tubing straightened out by sliding it into a length of 3/4 inch PVC that is longer than the tubing. This will remove most of the curl, but not all of it.
    Second, cut a piece of 3/4 rigid PVC pipe that is longer than the depth of the jug and insert the PVC into the container so that it sticks out a few inches. Then, when you insert the tubing into jug, just slide it into the PVC pipe all of the way to the bottom.
    Note: Liquid chlorine can be dangerous. Please be careful when handling.
    Support the site
