Thread: Adding chemicals
    Jul 2011
    Webster,Wi
    59
    Adding chemicals
    Is there a rule of thumb for adding chems to the pool and how long before you can go back into the pool? My test kit just arrived and I will be doing a test tonight to see what i need to add. I know my ph is high going by the test stripes that came with the pool so after adding muriatic acid do you wait 24 hrs or can we swim sooner?
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    Aug 2010
    Dallas, TX
    4,052
    Re: Adding chemicals
    An hour is fine.
    Butterfly's Avatar
    South Carolina
    10,045
    Always add chems with pump running, and half an hour is fine.
    You're done SLAMing when:
