Thread: PH rise?
    Lastrites's Avatar
    Jul 2010
    Newark, DE
    26
    PH rise?
    I'm stumped on why my PH keeps rising from 7.4 to 7.8!!! Every week, I have been adding 15-17oz (Muriatic Acid) to bring the PH back down to 7.4 and what do ya know, we never stay put!!! Hopefully someone here can help me understand why this keeps happening. I use around 50oz. of bleach every evening after I run my water test.
    FC= 3
    PH= 7.8
    TA= 100
    CH= 200
    CYA= 40
    12,000 gallon 15'-30'AGP (Cartridge Filter) SPECK 1.5 hp (Pump) TAYLOR 2006 (Test Kit)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: PH rise?
    A pint a week? Hah! That's child's play. You are not alone...
    My guess is you have hard water. You probably also get a lot of aeration from kids. Or a slide.
    Keep plugging away at it, eventually your pool will settle down into the sweet spot where pH flatlines for a week or two at a time. Although every time you add water, you disturb that.
    Re: PH rise
    Try going to pH 7.2 when you adjust pH. Your TA is still a bit high and if your pool has much aeration, as in a spillover spa, or jets that break the surface of the water, that agitation combined with the TA drives pH up quickly.
    I have all those, and now with TA at 70, ph is much less of a problem. That is, we add acid every 3rd or 4th day.
    Jun 2010
    Glendale, CA
    513
    Re: PH rise?
    TA buffers your PH but it also acts as a source of rising PH. Most pools are chlorinated with TriChlor pucks which are acidic so most places will recommend a highish TA (100 or so). Since you are using bleach you dont have this source of acid and must compensate with MA.
    As Anon mentioned - if you were able to drive your TA down to 80 or even 60 you may find your rising PH problem gets better.
    You can also consider adding borates to your pool. This wont affect the total amount of acid you add over time, but will slow the rise in PH.
    What;s the TA of your fill water?
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    May 2011
    Clearwater, FL.
    446
    Re: PH rise?
    My pool did the same thing. See link here:http://www.troublefreepool.com/what-...st-t36092.html
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
