Thread: Algae question
    Algae question
    Why does some algae make pool water turn totally green, even dark, murky green, while in other pools the algae will just grow on the walls and bottom while the pool water stays clear and blue?
    Howell, NJ
    24'x52" Round AGP, j-hook liner, resin frame, 1 hp pump, sand filter, new fill well water (6/7/2011).
    14,600 gallons
    Feb 2008
    Denton, TX
    5,061
    Re: Algae question
    A totally green pool indicates algae that has been left to grow unchecked. All algae starts out as a little greenish patch on the walls or as water that is a little cloudy.
    30,421
    Re: Algae question
    Additionally, I have read that there are around 7,000 different species of algae.....each with there own characteristics.
    Re: Algae question
    Interestingly when I get algae it tends to be crystal clear water... no green on sides, bottom or steps, and typically I will notice it floating in the water! If I look closely I will then see some on the plastic of the skimmer inside the pool!
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
