Thread: Pump just died - Need help ASAP may have to buy new pump
    All, I could really use some help. My pump is dead. I've got an electrician friend coming over to check it out but I'm planning for the worst. I may need to order a pump right away. Any suggestions for a good pump that wont break the bank for a 24,000 gallon in ground pool?!?
    24,000 G, Sand, IG, Vinyl
    Re: Pump just died - Need help ASAP may have to buy new pump
    I have a Amazon Prime account so I can get overnight shipping for $4 and it looks like they have a good Hayward selection but I am open to options!
    Ouch
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Quote Originally Posted by CGS
    Ouch
    I think you mis-spelled
    Try just getting a new motor. If you can get the model number off the old one, you can just buy that and save >50% of the price of a new pump. Amazon sells motors as well as pumps, so you may be able to still go that route.
    I'm having trouble getting the right frame size off the label as it is washed out pretty bad. I know it ends with J but I'm having trouble telling if it is 56 59 50 39 36 etc. I'm hoping it is a 56J as a local motor shop has then in stock.
