Thread: cloudy water
    cloudy water
    I have a 27 ft round AG vinyl pool. todays test shows:
    FC 4.5
    CC 0
    TC 4.5
    pH 7.8
    T/A 120
    CYA less than 20
    I know I need to add stabilizer, but will that help clear my water? It is cloudy but not green!
    any help will be appreciated. Thanks
    27 foot above ground
    sand filter
    Hayward 1.5hp pump
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cloudy water
    Do you have a CH#?
    You're done SLAMing when:
    hawkeye's Avatar
    davenport,iowa
    118
    Re: cloudy water
    most likely it is your cya level it is real low,you need to get it up to 50 ppm right away before you start to have other problems........your chlorine wont last long with that low of cya level and i suspect that 4.5fc will be down to 0.0 which means you wont have any chlorine in it by tonight if your pool is in the full sun today...so get stabilizer in there quick............
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cloudy water
    You can do an overnight free chlorine loss test "OCLT" and rule out/or in organics.
    Odds are that you have algae and need to shock.
    It would be a good idea to raise your CYA to about 30 for now, until you determine whether or not shocking is needed.
    Have you been backwashing your filter?
