Thread: LED lighting question
    Hi there, I have a question about some pool lights. Have an L shaped vinyl liner pool - 24 x 40 ( 16 x 24 deep butting up to a 16 x 24 shallow). Have one light on the deep end shining down the 40' stretch and also have another light on the shallow end pointing down the 24 feet stretch toward the steps. These are the old standard white Pentair lights. Want to switch over to the LED Intellibrite lights but not sure that I care to go with the 5G colored ones (expense and probably wouldn't use the different colors anyway) - thinking more like the white. But if I went with the white, not sure which wattage I should get. The liner is medium dark blue. Any advice is appreciated - just replaced liner and need to make a decision on these lights very soon.
    SBH
    Carrollton TX
    18k gallons, 3-6 ft deep
    IG, Plaster
    DE Filter
    I know nothing about pools
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: LED lighting question
    You have a big pool, so I'd get the biggest lights. With a dark liner, the extra light will help.
    Others feel free to comment, since I have a tiny pool with a tiny light...
    Columbus Ohio
    178
    We did a 16x32 ft pool and we put two LED lights in the pool, the are the G5's we love the color changing lights- it may be over kill on lighting in our pool but it is an entertainment pool as we do not have children so we like the bright lights, the LEDs are great so far
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
