Results 1 to 7 of 7
Thread: Black Dot Stains
    Black Dot Stains
    Not sure if this is the correct place for this question so I apologize in advance if it's not.
    I have flagstone coping that has little black dots that look like mold. I tried to use bleach solution and SS brush but they would not budge.
    Any idea what they are and how to get rid of them.
    14,000 gallon IG plaster pool, Cartridge Filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Black Dot Stains
    Pictures needed!
    Black Dot Stains
    Pics
    Black Dot Stains
    Put a few drops of straight bleach on one of the dots and let the bleach completely dry/evaporate before rinsing to see what that does.
    Support the site
    Quote Originally Posted by JamesW
    That just bleached the stone a little..
    I think that the bleach test probably rules out mold or lichens. It might be some type of metal oxide in the stone, perhaps manganese, iron, copper or cobalt. You could try some white vinegar on a test spot to see what happens.
    You could also try ascorbic acid (vitamin C) or oxalic acid. Barkeeper's friend contains oxalic acid.
    Oxalic acid
    You could also try a sulfamic acid based cleaner.
    Another possible solution is Super Iron Out Rust Remover, which contains sodium metabisulfite, and sodium hydrosulfite.
    Note: Acids might damage the stone. Always try a test spot to be sure. Acids might weaken the stone and the damage might take a while to become evident, so there is some risk from using acids.
    Another thing you could try is trisodium phosphate (TSP). Most TSP is a TSP substitute; you should make sure that the box actually lists trisodium phosphate on the label.
    Support the site
