Thread: Pool light wiring question
    Got a question that certainly has a quick answer.
    I'm replacing a couple of pool light assemblies and when I opened the J-box in the deck it was packed with a sort of putty.
    Makes sense, since it's protecting the connections, but what kind of putty/ packing is it exactly? Plumber's putty? Modeling clay?
    After many years it's still pliable.
    Any suggestions?
    Thanks, Pete
    Inground free form, 26,000 gal, tired paint over plaster, Intelliflo VF pump,
    Targus TA100D sand filter, Pool Valet infloor cleaning
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Pool light wiring question
    I'll bet it's silicon grease. It's nonconductive, and protects the wires from oxidizing. And bleach is a strong oxidizer!
    Feb 2011
    Sicklerville, NJ
    80
    It's called Duct Seal Like this
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    MajorDIYer - Spot on I think, based on a read of your link.
    Richard320 - You're right, silicone grease is an excellent sealer. I was a little concerned it might migrate down the conduit. I can worry about anything!
    Thank you both for taking a moment to help.
    Pete
