Thread: SWG
    Jul 2011
    Webster,Wi
    62
    SWG
    My wife and I bought our first pool this year and we are very green. I've got a couple questions,on my pump I can change from swg to just filtering. Is there any reason or when should I change to just filtering? My TF-100 will be here this week, going by the test stripes from Intex my ph is above 8 I'm guessing. We were at Walmart and I purchased some conditioner and ph minus. Is there anything I should do before I can get a good test done, the water is very clear.
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    22,551
    Re: SWG
    I can't think of a reason to change to just filtering unless you're shocking. Then you could turn it off and raise the FC with bleach or liquid.
    30,426
    Re: SWG
    Test strips are very, very unreliable but seem to do fairly well at testing pH.
    If your results consistently show pH at 8.0 or above, you could lower pH down to 7.5 and then double check it with the pH test in your TF-100 when it arrives. I would wait on everything else until you can post a full set of test results.
    Jul 2011
    Webster,Wi
    62
    Re: SWG
    Is the ph minus from Walmart a good product to use or should I get something different. The problem I have is that I live an hour away from any pool store but the local hardware store might carry something.
    Re: SWG
    Muriatic acid, available at most hardware stores, is the best thing to use to lower PH. PH Minus is also alright, but tends to be significantly more expensive.
