Thread: Low bather load in the sunny North Texas area
    Jul 2011
    McKinney, Texas
    4
    Chem Geek
    For a low bather load in the sunny North Texas area, what would you recommend? Here is what my pool builder is recommending:
    Rainbow 320 Chlorinator
    Nature 2 Mineral Sanitizer
    Del Ozone Eclispe 2-Corona Discharge Ozoneator System (No UV Lamps)
    South Central NJ
    3,192
    Re: Corona Discharge vs UV ozonaters vs salt water?
    Nature 2 injects metal ions. Not a good thing. We don't like N2 here. The cartridges are very expensive and need replacing every 6 months. High margins for the builder and low benefit for the pool owner. Thats a pass on it item and put the money elsewhere.
    Ozone can only supplement chlorine. Won't hurt anything but will require periodic service and maintenance. On a lightly used pool, you will use more chlorine. High margins for the builder and low benefit for the pool owner. Thats a pass on it item and put the money elsewhere.
    Rainbow 320, as an erosion feeder, is the best of breed. But using tabs on a year round basis means periodic dilutions of the pool water to keep the stabilizer level in check. I have one on my pool. If I had a salt cell, I would still have one as a backup. Expect to add baking soda and either borax or washing soda periodically.
    Salt cells and liquid fed systems typically need acid added periodically.
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2011
    McKinney, Texas
    4
    Re: Low bather load in the sunny North Texas area
    So would you recommend a Aqua Pure Automatic Salt Chlorine System
    with the Rainbow 320 Chlorinator and cut the Nature 2 Mineral Sanitizer?
    Additionally, do not add the Del Ozone Eclipse 2-Corona Discharge Ozoneator System?
